Author Topic: monitor for cocktail  (Read 1593 times)
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« on: February 24, 2004, 01:26:07 pm »
would this be a good monito to use for a cocktail ms pacman?
I am waiting to get a model number from the seller.  I am hoping it's a vga so i can use an old laptop in the cab.  otherwise I will need t he arcadevga form ulitmarc.  basically what i need is a few comments.
EDIT LOL forgot link
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3276712741
« Last Edit: February 24, 2004, 01:36:17 pm by AX »
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:monitor for cocktail
« Reply #1 on: February 24, 2004, 03:21:30 pm »
sure I guess, provided it physically fits in your proposed cabinet (what size monitor did ms pac cocktails have originally...? most likely it will fit)... it is a "real" arcade monitor so your best bet is to couple an arcadeVGA card with it, which rules out your laptop.
good luck with your project!
rampy
AX
« Reply #2 on: February 24, 2004, 03:32:59 pm »
well,  i started to use a 19" pc monitor.  I even got the tube installed.  problem is it's left apart with the flyback out of it and everythign dismanteld now for about a year. lol.
paigeoliver
  • Awesome face!
« Reply #3 on: February 24, 2004, 03:44:49 pm »
Those monitors are not VGA. Or if they are, then the seller is providing an incorrect description since he describes them for use in Pac-Man and Defender.
And standard 19" framed (arcade style) monitor should fit in your Ms. Pac cocktail, although you MIGHT have to rework the frame slightly to use some brands.
PC monitors will also work, but will probably have to be decased.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: February 24, 2004, 06:50:12 pm »
That's an Imperial International/Kortek monitor. Those are excellent arcade game monitors. They are CGA (standard res).
Lilwolf
« Reply #5 on: February 25, 2004, 06:20:08 am »
There is another place that sells 19" monitors shipped for 200 bucks...
GREAT deal for BOTH cocktails and standups.
I have a 27" monitor and am considering moving down to 19".  Mainly because its hard to see the entire screen at once.  Games like robotron you loose something on larger screens... Harder to take in EVERYTHING thats happening.
I'm also considering creating an auto-bezel creation for games that don't have one.  This would allow for text help/moves to be displayed around the edges... but will take any screen into any end size.    (so if you have a 25" monitor, you can make it a 19" and add comments around the edges from the history.dat or controls.dat.
Nailz
  • Last login:April 23, 2014, 08:55:03 pm
« Reply #6 on: February 25, 2004, 10:36:54 pm »
How about sharing that place with us?   ;D
