Author Topic: Question about Non-Integer Scaling  (Read 2060 times)
tonyt76
  • Last login:March 11, 2024, 10:06:18 am
« on: February 25, 2021, 03:27:45 pm »
Which is the best option to use on a CRT? I believe default is set to X Only.
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 06:27:50 am
  • Quote me with care
Re: Question about Non-Integer Scaling
« Reply #1 on: March 02, 2021, 04:10:22 pm »
Not sure what you mean. Best in what circunstance? GM automatically configures the best scaling settings for each situation, if that's what you mean. If possible, it always uses integer. When using super resolutions, it will use fractional scaling on X axis and integer on the vertical. When there's no other option, it'll use fractional. You can force either of these options by command-line or game-specific inis.
Steps to create a log:
