Author Topic: Megatouch ion 2010 games  (Read 10050 times)
freshfitz
  • Last login:January 29, 2025, 05:17:10 pm
« on: February 22, 2021, 11:22:12 am »
I loaded a Megatouch force ION with 2010 and 2010.5 neither have run 21 in it. Did they get rid of run21 after a certain year?
Re: Megatouch ion 2010 games
« Reply #1 on: February 22, 2021, 01:57:01 pm »
i know for sure it's on 2011, so i don't think it's been removed...
go into the operator screen and into the game list see if maybe it's been disabled.
freshfitz
« Reply #2 on: February 22, 2021, 06:22:04 pm »
It's absolutely not there run 21 and zip 21, I even re-loaded a new hard drive.  I sware they were on the force 2009.
 I wish there was a game list for the years
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
« Reply #3 on: February 23, 2021, 12:11:30 am »
If its not in there, then you might have got a oregon key or some other region key that is stripped down. Press the spinning hand in the top left corner and take a pic of the screen so i can see what region key you have.
freshfitz
« Reply #4 on: February 23, 2021, 07:44:26 am »
SA-3590-06 is that a restricted key?
freshfitz
« Reply #5 on: February 23, 2021, 12:57:24 pm »
Looks like it is an oregon, guess that explains it, thanks never new there was a key that restricted certain games
tlandrews
  • Last login:May 28, 2024, 06:47:21 am
« Reply #6 on: February 23, 2021, 11:18:23 pm »
Show us how you mounted an Intel board in there
freshfitz
« Reply #7 on: February 24, 2021, 07:16:14 am »
Intel mobo
freshfitz
« Reply #8 on: February 24, 2021, 08:04:27 am »
What does the push button on the outside of the bezel do on the ion's ?
« Reply #9 on: February 24, 2021, 11:26:12 am »
I assume you meant the round thing in the top right hand side of the game?
it's a reader for a player key. it stores your login info on the key so when you play a game, you can just scan your key (hold it on the button for a few seconds) and it automatically puts your info in so you don't have to manually enter it each time (high scores...logging in for online things etc.)
mahkeymike
« Reply #10 on: February 24, 2021, 05:52:43 pm »
You can also use a operators key so you don't have to manually open the machine up to press the operator setup button.
1st
  • Last login:November 03, 2021, 11:01:33 pm
« Reply #11 on: March 01, 2021, 10:14:33 pm »
So any 945GC motherboard will work in an ion game? Or is there a specific model? Thanks
