Author Topic: Crt EmuDriver and other emulators  (Read 2118 times)
Retro77
  • Last login:September 29, 2023, 08:50:10 am
« on: February 21, 2021, 04:24:35 pm »
Hi all,
I have a PC with CRT EmuDriver installed. If I wanted to correctly configure and use any other emulator do I need to select which resolution from the generated list that most closely resembles the emulator's original resolution and that is all, or is there more to it than that.
I would like to incorporate Model 2 emulator and Supermodel if that is possible. As I am using a 31khz monitor, matching the original resolution won't be possible. But I hoped I could maybe get it close.
As it stands, I have both setup as 640x480 but I can still see some screen tearing on some games so am assuming in have something wrong somewhere. The game I can see it in most is Indy 500 and the 'Ladies and Gentlemen' intro section.
fuchi_jeg
  • Last login:Yesterday at 02:13:39 pm
Re: Crt EmuDriver and other emulators
« Reply #1 on: February 21, 2021, 05:33:02 pm »
Native for m2 is something like 490x390. You will probably get screen tearing if you use non native resolution.
Retro77
« Reply #2 on: February 21, 2021, 06:17:29 pm »
Thanks for that, fuchi_jeg. So, as long as I match up resolutions nothing else has to be changed. I wasn't sure if I was missing anything else.
To be fair, even at 640x480 all other games look great.
fuchi_jeg
« Reply #3 on: February 22, 2021, 12:49:10 pm »
Correct. GM's will maintain the correct timings as far as I know.
