Author Topic: Spectra Eclipse + I-Pac Ultimate  (Read 2294 times)
DiB
  • Last login:July 13, 2021, 09:53:20 pm
  • Why can't everything just be software?
« on: February 18, 2021, 09:52:47 pm »
I have an I-Pac Ultimate and want to wire in a boat load of Spectra Eclipse RGB buttons.  Unfortunately, the Spectra Eclipse buttons have no termination on them and the I-Pac has what I think are 4-pin connections.  Given that I have a ton of these buttons to wire, what is going to be a good way to make these connections so that they are solid?  Is there a harness of some kind? (my google-foo is failing me here.)
  • Last login:Today at 12:28:20 am
Re: Spectra Eclipse + I-Pac Ultimate
« Reply #1 on: February 18, 2021, 11:53:17 pm »
Here are two approaches to consider.
1.) Crimp female Dupont pins on the Spectra Eclipse RGB wires and insert them into 1x4 (recommended) or 1x2 or 1x1 Dupont housings.
- This requires a decent ($25?) ratcheting crimp tool and some practice crimps to perfect your technique, but is the best and cleanest way.
2.) Use Euro terminal strips and M-F Dupont jumpers.
- Pull the 1x1 Dupont housings on the F end of the jumpers and use 1x4 housings. (optional but recommended)
- Easier to do than #1 above, but it takes more space.
- Use one 12-position strip (shown below) for 3 buttons.
      Spectra Eclipse RGB wire ==> Euro terminal ==> (M) jumper (F) ==> Ult. I/O LED pin
« Last Edit: February 19, 2021, 12:17:57 am by PL1 »
DiB
« Reply #2 on: February 19, 2021, 07:47:49 pm »
Much appreciated.  And I appreciate the patience with my lack of hardware skills!
