Author Topic: Grounding and i-pac  (Read 960 times)
Drakkorcia
  • Last login:September 02, 2024, 01:24:35 pm
Grounding and i-pac
« on: February 06, 2021, 12:01:26 am »
I bought an i-pac with associated wiring and have the signal wires installed into the screw connectors. The only thing left is the ground daisy chain but it has the usual .187 female spade terminals throughout the entire chain; there is no tinned end on either end. Do I need to cut off one of the terminals at one end of the ground chain so the bare wire can be screwed into the i-pac? Or am I missing something?
