Author Topic: RGB Commander Issues  (Read 6564 times)
ryanbush
  • Last login:March 18, 2021, 01:29:00 am
« on: January 29, 2021, 05:49:34 pm »
Hello im very new to this forum and just got my first ultimate io board for my arcade. I run Retropie on a pi 4 8GB model. I was able to get the files on there but when I did this command:sudo ./setup.sh install it came back with this:
● rgbcommander.service - RGBcommander arcade led and joystick daemon
   Loaded: loaded (/etc/systemd/system/rgbcommander.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2021-01-29 18:53:01 GMT; 3s ago
  Process: 3934 ExecStart=/usr/sbin/rgbcommander/rgbcmdd (code=exited, status=0/SUCCESS)
 Main PID: 3935 (rgbcmdd)
    Tasks: 8 (limit: 4915)
   Memory: 9.4M
   CGroup: /system.slice/rgbcommander.service
           └─3935 /usr/sbin/rgbcommander/rgbcmdd
Jan 29 18:53:01 retropie systemd[1]: Starting RGBcommander arcade led and joystick daemon...
Jan 29 18:53:01 retropie systemd[1]: Started RGBcommander arcade led and joystick daemon.
Jan 29 18:53:04 retropie rgbcmdd[3934]: sh: 1: /usr/sbin/rgbcommander/scripts/OnDaemonStart.sh: Permission denied
Can someone please help? I'd appreciate it a ton.
mahuti
Re: RGB Commander Issues
« Reply #1 on: February 01, 2021, 05:38:39 pm »
Run this and tell me what you see...
sudo ls -al /usr/sbin/rgbcommander/scripts
