Author Topic: MAME BGFX Shader on vertical roms strange moirč effects  (Read 3489 times)
xbrunox
  • Last login:August 30, 2025, 05:03:06 pm
« on: December 21, 2020, 03:14:13 am »
Hi everyone.
I have a problem with BGFX shaders.
when I apply CRT geom deluxe to horizontal games everything is fine.
when instead I apply it to vertical games I have a strange moiré on the screen and it almost seems to see a repetition of the pattern.
is this normal?
or is there a special shader for vertical titles?
thanks.
xbrunox
Re: MAME BGFX Shader on vertical roms strange moirč effects
« Reply #1 on: January 25, 2021, 10:21:23 pm »
Nothing? Noone?
jrf06
  • Last login:April 03, 2023, 03:00:21 pm
« Reply #2 on: March 18, 2023, 07:49:35 am »
Hello, I know it's been a while, but I'll leave this information in case it helps someone. I also had the same problem as the scan lines were overlapping. What I did was modify the ini file called vertical.ini
add these lines
# CORE RENDER OPTIONS
keepaspect                0
unevenstretch            0
unevenstretchx          0
unevenstretchy          1
autostretchxy            0
intoverscan               0
intscalex                 4          <-- is for 1080p
intscaley                 4          <-- is for 1080p
what this configuration does is keep the aspect ratio of a horizontal monitor flipped to vertical, this allows the scan lines to be displayed correctly and not overlap, of course the games look a little more stretched than their original proportion set mame, but I remember that in the arcades the technician rotated the monitor of a horizontal arcade and left it as vertical for ship games, it's the same thing that this jsjs configuration does.
Excuse my lousy English since I used a translator
« Last Edit: April 03, 2023, 03:00:21 pm by jrf06 »
