Poll
If you could have ONE steering wheel that "does everything you need", which configuration do you consider THE BEST choice for you? Each 'mode' of operation would be independent of the other, ie., you can't have 270 spring loaded RTC and FFB
Just a 360 degree spinning wheel, to play games like Pole Position, Sprint, Super Off Road, etc. (These are readily available today)
0 (0%)
Just a 270 degree spring loaded (Return to center) wheel to play games like Outrun or Cruisin' USA. (These are readily available today)
0 (0%)
Just a force feedback steering wheel for PC or more modern driving games. (These are readily available today)
1 (33.3%)
A combination of 360 degree spinner and 270 degree spring loaded (Return to center) that plays most arcade games, selectable on-demand.
1 (33.3%)
A combination 360 spinner, 270 spring and DIY force feedback (you add your own stepper motor, direct drive or belted, to the wheel and configure yourself), each mode selectable on-demand.
0 (0%)
A combination 360 spinner, 270 spring and pre-configured direct drive force feedback, each mode selectable on-demand. This would be the most expensive option, obviously.
1 (33.3%)
Total Members Voted: 3
Author Topic: VOTE NOW: Best MAME arcade steering wheel features on your wish list  (Read 2957 times)
SofaKingRotten
  • Last login:March 01, 2023, 11:27:05 pm
 :dunno
« Last Edit: December 07, 2020, 04:57:20 pm by SofaKingRotten »
