Author Topic: Volcano button mod - adapt to regular button hole [link for download of STL]  (Read 1068 times)
negative1
  • Last login:Today at 07:17:35 pm
in case some of you may find this useful:
I'm having a friend add volcano buttons to the dig dug countercade.
Here's the progress:
A recent project for a friend in the A1Up community: 3D-printable adapter for Atari "Volcano"-type power switches.
I'm no 3D printing expert, but I put this together for a friend here in the A1Up community. Printed in black PETG, it's flexible enough to squeeze the "tabs" through the hole, but stiff enough to prevent it from easily popping out. You could put a dab of hot glue across the "tabs" to keep it firmly in place. Download the STL here: https://drive.google.com/file/d/1UMUOr1xPkI5CTbJqYggzzoLPjvHle1dX/view. These reproduction switches were used: https://www.arcadeshop.com/i/1539/atari-lighted-start-push-button.htm
Not shown is wiring up power to the LEDs. All A1Up control panel circuit boards have 5V, and these draw a minimal amount of current. Use a multimeter to find the appropriate pins for 5V and ground, and solder wires to them. (Or get 5V from elsewhere if you're using a Pi, Pandora's Box, etc.)
once i get it, i can show more pictures, details, etc.
later
-1
Nice solution.
