Author Topic: Noob question going to an ipac 4  (Read 1766 times)
Montell
  • Last login:June 11, 2022, 02:51:48 am
« on: November 22, 2020, 06:05:25 pm »
I am not good with wiring nor i am i much of an electrician, when i originally wired my cabinet it was with zero delay encoders and a raspberry pi. After getting an i7 2015 from work for 25 bucks and putting in a decent graphics card, i have gone to a pc. With that I am planning to now put in an ipac 4.
I have a friend who is good with electrical that could assist, but rewiring my cabinet i see the sanwa joystick connectors I need have a ground wire. Since its a 4 player panel that means 4 ground wires for each joystick using these connections, I posted a link below of the sanwa connection. I also have a mix and match of some .110 sanwa buttons but a few .187 buttons for start (I can only find those), so I am unsure how Daisey chaining will work, and how many ground buttons can be Daisey chained.
https://www.amazon.ca/JLF-H-Wiring-Harness-Joysticks-Seimitsu/dp/B01GE752BY
And I am looking at this wiring kit
https://retroactivearcade.ca/products/i-pac-4-wiring-kit-1
Obviously the ipac wiring harness has the Daisey chain loop but with only two ground connections, how would i ground the other joystick connections? Or what would i need to ask someone with electrical experience to do?
And how many ground connections can you make in the daisey chain loop? I have 36 .110 connectors and about 5 .187 connectors.
Any help is appreciated.
« Last Edit: November 22, 2020, 06:44:40 pm by Montell »
bobbyb13
  • Online Online
  • Last login:Today at 11:26:47 pm
Re: Noob question going to an ipac 4
« Reply #1 on: November 23, 2020, 05:46:43 am »
You can link as many grounds together on the same pcb as you want.
Logic ground is logic ground.
Those joysticks have their own circuit board and the ground for every directional input is linked together for you already, so you have only 5 wires instead of 8.
One wire each for L, R, U, D, and a common ground.
For clarity you can daisy chain the player 1 joystick and all player 1 button grounds together and the player 2 joystick and all player 2 button grounds together- utilizing only two ground connections total on the Ipac.
You really could bond every ground in the whole panel together if it all goes to the same interface board and it wouldn't make a difference to the board.
Those impulses/loads are so small, short lived, and travel so fast that it doesn't matter.
If your friend is a real electrician he/she will tell you that you would NEVER do this in the wiring in your house.
 :lol
