Author Topic: Searching help to use the arcade monitor of a virtua striker 2 cab  (Read 3018 times)
ame.masia
  • Last login:November 24, 2020, 05:54:11 pm
Hello everybody, I'm writing from Italy, this is my first message here.
Excuse my English, maybe I don't know all needed words to describe and explain what i need, forgive me if this happens.
I have a Sega cab with a Samsung monitor and i want to connect it to an orange pi board with an hdmi to vga out and a gbs8100 vga to cga converter.
I can also use a raspberry pi instead if needed.
I know it's not the best quality setup for a good video output, but for now this is what i have...
My gbs8100 board should be able to output rgb-synch signal to the monitor and i successfully use it on another cab with this same setup. That screen is a 15khz one, while this seems to be a 25khz one.
On the screen main board there is a double connector high low, is that to output 15khz on this screen?
How should i connect my board to the screen?
If i connect using the 5 wiires you see in the photos that are output of the gbs8100 i have black screen with some moving lines on screen as you can see on one of the photos.
In the attachments:
The screen model number
The high low connector
An unknown connector
The cab has no board inside
The input "connector"
« Last Edit: November 02, 2020, 04:00:58 pm by ame.masia »
ame.masia
Re: Searching help to use the arcade monitor of a virtua striker 2 cab
« Reply #1 on: November 15, 2020, 09:15:55 am »
Every little help or information would be greatly appreciated...
jennifer
« Reply #2 on: November 15, 2020, 12:14:11 pm »
My first thought would be a signal issue, And would double down on making sure that chassis works at all by plugging a good board to it as a jumping off point, That high/ Low would be yoke induction I am guessing and taking a reading of the horizontal winding would be a good double check to be plugged into the high side.
grantspain
« Reply #3 on: November 15, 2020, 04:24:06 pm »
sanwa pm1745, change resolution jumper from high to low so the chassis is then set to 15khz
ame.masia
« Reply #4 on: November 15, 2020, 05:53:45 pm »
I was working all day, i saw replies just now, thanks for suggestion, i will try tomorrow and report.
grantspain
« Reply #5 on: November 16, 2020, 03:09:26 am »
also white wire on japanese cabs is ground so you need to swap the white and blue/white wires on the rgb
ame.masia
« Reply #6 on: November 24, 2020, 05:54:11 pm »
Thanks for this suggestion! I was wondering about that white cable that was not corresponding with other wires connected to it.
I didn't had any success yet with my complex setup, I'm waiting to have a pandora's box and then try with an easier setup to find a solution.
