Author Topic: Recommendations for replacement microswitches on a Happs super joystick  (Read 3554 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
So I have some old happs competition joysticks I want to move over to a new project. They're in great shape, but I need to replace the  rmicro switches and the leaves that comes with them. Any recommendations? From looking around online it sounds like the new happs is not the way to go.
« Last Edit: October 13, 2020, 03:10:35 am by Shieldwolf »
  • Last login:Yesterday at 01:17:11 am
Cherry switches are the best, but they were designed for heavy arcade use so honestly just search for microswitches on ebay or amazon and anything that comes up with a decent price will be fine.
Shieldwolf
  • SpearShield.com
Thanks Howard.
One last question. Most micro switches I find don't have the longer metal leaf on the top that the joystick hits at angles. Is there a name for that actuator? Picture below is an example of what I'm talking about.
Thanks again.
« Last Edit: October 12, 2020, 03:39:00 am by Shieldwolf »
    • GroovyGameGear.com
Competitions don't use those kind of switches, but they are called levers.
Shieldwolf
  • SpearShield.com
Here are mine. The other was reference only. Though it is concerning that it was listed as a happs competition joystick.
KenToad
  • Last login:Today at 03:49:00 pm
  • Flap Flap Flap
Maybe the seller meant that the joystick was competitive?
To me, that looks like a Happ Super without the actuator or c-clip, although I'm no expert.
Yeah there should be a square actuator on there and regular switches if I haven't gotten my sticks mixed up again.
Shieldwolf
  • SpearShield.com
First, can I say it's been a long time since I have been on these forums and it warmed my heart that the first two responses were from Howard and Randy T.  Thank you gentlemen for the help.
Second, Don't worry about he stick with green switches. I'm not buying it/them. It really was just to get a photo of a "lever on a micro switch".
My joystick is the one with the rat nest wires. Yes the actuator is missing at the bottom in the photo, I am taking contorller apart. It is a competition joystick from happs unless happs sent me the wrong joystick back in 2004.
Those are the original switches with levers that came with it. I just wanted to know if there was a specific recommendation for a similar switch with a lever. I went to the happs site to see what switches they recommended.  I could literally buy a new joystick for the same price (crazy!).
So any recommendations for switches with the neededlever or good site that would have them at a reasonable price would be greatly appreciated.
Nah if you look at regular switches they actually have the slot molded in for the lever so it'll literally be the same switch except for that blade.  I don't know if randy carries anything like that or not.... I just head on the old eBay and filter to north America only so I don't have to wait three weeks to get them.
KenToad
  • Flap Flap Flap
It's definitely not a competition joystick, as they have a square actuator and no levers. You ordered directly from Happ back in 2004? I did the same at nearly the same time, probably back in 2005. Bad luck if they sent you the wrong sticks and you didn't notice. However, the super joysticks are also excellent. It's just that the lever switches will probably run a bit higher than normal switches, as the lever ones are less common.
Shieldwolf
  • SpearShield.com
Modifying the original post.
Well you guys aren't wrong. They are in fact supers, but it's funny they don't have the shorter fat tops but the longer thinner competition style oval tops. did the supers come with those?
« Last Edit: October 13, 2020, 03:15:45 am by Shieldwolf »
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
Re: Recommendations for replacement microswitches on a Happs super joystick
« Reply #11 on: October 13, 2020, 07:19:56 am »
Maybe someone customised it. The Happ Competition and Super handles are somewhat interchangeable. They have the same diameter but slightly different distances from the pivot point to the first groove. However, I've managed to swap them over in the past by using washers to pad out the distance from the pivot point to one of the grooves.
Shieldwolf
  • SpearShield.com
« Reply #12 on: October 13, 2020, 11:27:34 am »
These were a straight happs purchase so doesn't seem likely. For what it's worth I think they're great.
