Author Topic: Quick question - How to uninstall crt emu driver without the amd video card?  (Read 3206 times)
digitron
  • Last login:April 01, 2022, 12:46:33 pm
Accidentally disabled composite sync getting vmmaker modes dialed in for a newly modded rgb screen. I have to remove the amd 5000 card to get the onboard video to work (old dell optiplex). The crt emu driver setup only provides the option to install/uninstall if the amd card is inserted. My AMD video card has Atom composite sync flashed.
Any workaround for uninstalling crt emu driver so I can reinstall it with the correct settings?
GM 224, Win7 64 Bit, i5-2400 @ 3.1Ghz, ATI HD 5750, 8GB RAM, 256GB SSD
Sereosh
  • Last login:August 26, 2023, 11:27:13 am
  • Last login:Today at 05:45:19 am
You should be able to handle this situation with two monitors. Your card can still output to an LCD normally while sending 15 kHz through its VGA port. No need for removing the card physically.
digitron
DDU https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Thanks for that link, good to know.
Thanks Calamity, I got it working through the 2nd DVI port on the AMD card, just had to find another DVI > VGA adapter.
