Author Topic: CRT to PC trouble.  (Read 1877 times)
onedudesmind
  • Last login:October 09, 2020, 07:34:25 pm
CRT to PC trouble.
« on: September 12, 2020, 05:54:00 pm »
Converting a Tekken 4 showcase arcade machine to a custom mame PC. it has a CRT monitor i would like to use already in it, it has an RGB cable out of a Jamma(b) card which should allow me plug in right into my PC. When i do this I can see the image on the monitor but it is spinning like an old V hold issue (monitor works fine with the games main board). I've tried various resolutions and Refresh rates with no luck. Any help would be greatly appreciated have hit a wall of sorts on the build .
Josh128
  • Last login:January 09, 2021, 11:32:25 am
Re: CRT to PC trouble.
« Reply #1 on: September 14, 2020, 01:56:58 pm »
Do you have a Vhold adjustment on the chassis or remote board for the monitor?  I think you should somewhere.  What kind of monitor is it? 15Khz, 25KHz, 31KHz?  Are you using CRTemudriver on the PC driving the monitor?
buttersoft
  • Last login:Today at 07:20:39 pm
  • Is running at 15kHz
« Reply #2 on: September 15, 2020, 01:48:47 am »
Specs seems to say the Namco 246 system and Tekken 4 output both 15 and 31kHz. Not sure if you can set the game to one or the other, or if it uses both for FMV vs in-game or what.
So, yer, more info pls. What make/model of monitor is in the cab? How is the picture rolling, vertically, horizontally or diagonally (both)? What PC hardware, OS and software are you using? What type of RGB cable, what connectors, and wtf is a Jamma(b) card?
