Author Topic: Brand new Mala install finds 0 games, but why?  (Read 1934 times)
Ron_Michallick
  • Last login:October 04, 2025, 06:58:37 pm
  • MK64 has newer software, if you are interested.
    • MK64
« on: August 29, 2020, 02:51:50 pm »
I use Mala a lot of another machine but haven't done a new install in over a decade.
Mala is 1.7.4 ;  Mame is 0.200 ;  mame.xml is version 1.0 ; WinXP SP2
When refreshing list, it complains about controls.ini then later ends with no games found.  :banghead:  There are clearly four in the roms folder.
I have tried the initial setup more than once and I'm making zero head way. This wasn't supposed to be the hard part.
Ropi Jo
  • Last login:October 25, 2025, 01:57:17 pm
Re: Brand new Mala install finds 0 games, but why?
« Reply #1 on: August 29, 2020, 03:45:58 pm »
  • Online Online
  • Last login:Today at 05:43:08 am
« Reply #2 on: August 29, 2020, 03:53:16 pm »
XML format changed in MAME 0.162.
There's a manual workaround here or you can use ROMLister.
FWIW, romlister is now able to use mame 162+ files and generate all the gamelists your heart desires.
http://www.waste.org/~winkles/ROMLister/
Ron_Michallick
    • MK64
« Reply #3 on: August 29, 2020, 04:24:18 pm »
Yes, Yes. That was it. Many thanks.
