Author Topic: WG K7000 help  (Read 1764 times)
nitebreed
  • Last login:February 13, 2006, 09:35:24 pm
WG K7000 help
« on: February 19, 2004, 11:13:46 pm »
ok i just got my main monitor board back from the shop i had to send it to get repaired. I plugged everything up and turned it on there is a faded white screen with no picture i adjust the contrast ,brightness and then i get a picture but the problem is the picture is sorta blurry and the white haze it still covering the screen I haven't adjusted anything on the board it self. i know where the two focus knob are but as for getting rid of the white screen i dont know,as far as the brightness contrast,only effect the back picture not the white faded part i figure they had to adjust it to a monitor they had there since i only shipped the board here is a pic
thanks for anyhelp
« Last Edit: February 19, 2004, 11:16:38 pm by nitebreed »
nitebreed
Re:WG K7000 help
« Reply #1 on: February 19, 2004, 11:15:52 pm »
a picture
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
Re:WG K7000 help
« Reply #2 on: February 19, 2004, 11:35:14 pm »
WOW!
Is that a fuzzy camera or the monitor!?
I've got a 7000 series monitor, and can really help out (I hope).  What was the monitor in the shop for?
nitebreed
Re:WG K7000 help
« Reply #3 on: February 20, 2004, 12:55:35 am »
The board was working pretty good but was pulling to one side in the top corning, so i installed a cap kit in it plugged eveything back up and all i got was a black screen so i sent it off to get repaired they replace two parts as i can tell. since they never contacted me about what the problem was just showed up at my door with a cod charge of 56.99 after about a week and a half, but here is the what they charged for r-p538 wg25k7000 cga $29.99 and p10 electronic parts $10.00 the picture is alittle fuzzy but as u can see in the picture it has a white cast over the intire screen
nitebreed
Re:WG K7000 help
« Reply #4 on: February 20, 2004, 01:02:04 am »
here is what it looked like before i installed the cap kit and had to send it off to get repaired no white casting over everything
Ken Layton
  • Guru
  • Technician
Re:WG K7000 help
« Reply #5 on: February 20, 2004, 01:41:23 am »
The "SCREEN" control on the flyback is turned up too high. It's the bottom control on the flyback. The top one is focus.
nitebreed
Re:WG K7000 help
« Reply #6 on: February 20, 2004, 03:40:34 pm »
thanks it worked fixed her right up i tell ya......hahahahahah now for the gamming.........thanks again
