Author Topic: Is there a GroovyHBMame?  (Read 5875 times)
alex2005
  • Last login:December 20, 2023, 09:21:14 am
« on: July 02, 2020, 10:41:17 am »
Hi, I've been looking for a GroovyHBMame 0.221 or 0.222 - reason: this supports the rom samsh5fe - but can't find any updated build.
Is anyone aware if this build exists, if not how could I compile it on my own on Windows?
Thanks a lot !
psakhis
Re: Is there a GroovyHBMame?
« Reply #1 on: July 02, 2020, 05:49:03 pm »
Hi, you can build yourself with Calamity patch.
I tested and only ui.h needs some changes in patch, nothing important....i share in case you want to try it
https://drive.google.com/file/d/185QUcnCYDxrWqEW2_XLfB47vutwtbYt1/view?usp=sharing
alex2005
« Reply #2 on: July 03, 2020, 12:15:39 pm »
Thanks a lot! works perfectly!
psakhis
« Reply #3 on: July 03, 2020, 12:42:37 pm »
Nice, but the merit is from @Calamity, I just patched.  :cheers:
mrchrister
  • Last login:July 20, 2024, 06:14:53 am
« Reply #4 on: July 06, 2020, 09:00:35 pm »
What a timely thread. Thanks for the file! Was trying to play dktrainer on groovyhbmame 2.04 but didnt recognize it
« Last Edit: July 06, 2020, 09:02:51 pm by mrchrister »
alex2005
« Reply #5 on: August 17, 2020, 11:06:07 am »
Hi again :)
I'm trying to compile HBmame and want to include the groovymame patch + haynor666 patches ( to have a groovyHBmame with nonag etc).
Upon following the mame compilation tutorial I always get stuck as I can't apply the patch command (patch command not recognized). Tutorial that I try to follow is here: http://forum.attractmode.org/index.php?topic=348.0
Besides, I do not know if I should apply groovymame patch first, and then haynor666 patch? Or can I apply both in the same command line?
Which command should I use to compile two different diff files?
Does anyone have a groovyhbmame 0.223 nonag with haynor666 patches applied?
Thanks a lot (again!)
totozero
  • Last login:June 07, 2023, 07:36:05 am
« Reply #6 on: August 20, 2020, 10:32:36 am »
Now if you could compile a 0.223 version nonag with haynor patches, I'd truly praise you  :laugh:
Cheers.
alex2005
« Reply #7 on: August 20, 2020, 03:25:29 pm »
Definetely I would, too!
psakhis
« Reply #8 on: August 21, 2020, 05:10:51 am »
No problem at all!
https://drive.google.com/file/d/1ov5cF3DcR2apAGn1uv1J4Tzlf36IO7VO/view?usp=sharing
Tested in my cab and works fine, with all patches (nonag, haynor666 and of course groovymame)
alex2005
« Reply #9 on: August 21, 2020, 06:00:02 am »
Awesome!!! Thanks so much!! :cheers:
totozero
« Reply #10 on: August 21, 2020, 06:10:35 am »
Thanks mate, much appreciated.  :cheers:
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« Reply #11 on: October 14, 2020, 12:21:35 pm »
Any reason why using the same ini settings on both reg groovy mane and this hbgroovymame yield different screen positions on the same game?
alex2005
« Reply #12 on: December 31, 2020, 10:34:04 am »
Hello!
The latest 0.227 version of HBMame finally supports samsh5fe without intro bugs.
Does anyone have "groovyhbmame" nonag with this version available? I still cant figure out how to compile it myself, unfortunately :(
Thanks a lot!
mrchrister
« Reply #13 on: December 31, 2020, 11:21:28 am »
I always get my GroovyHBmame fix from @b4nd1t0
The most recent one is 0225 though.
https://b4nd1t0.blogspot.com/2020/10/mame-0225.html?m=1
Maybe worth contacting him?
BuckoA51
  • Last login:October 31, 2025, 11:29:53 am
« Reply #14 on: October 31, 2025, 11:28:38 am »
An old topic to bump but I was looking around for Groovy HB Mame myself and coming up empty, the link above seems to be dead, is there anywhere reliable where it can be downloaded?
