Author Topic: N00B Dad Mame Setup Issue - Help Needed  (Read 1599 times)
max.r.mccarty@gmail.com
  • Last login:July 29, 2020, 03:50:13 pm
« on: June 30, 2020, 12:22:28 am »
So I've spent the last 6 months slowly building my son a full-size arcade cabinet and I am finally to the part of configuring the PC, and getting the MAME games setup (in Launchbox).
My problem is that, with Mame 0.220, I have a ton of games, many that won't play, many that are specific to certain controls (I don't support - e.g. trackballs), missing CHD's, etc. Most likely a large portion of the few thousand games wouldn't ever be played (Launchbox does filter out some based on criteria).
Is there an easy way to get a list of top ~200 popular Mame games, that work, including any additional bios/CHD's needed OR put the list together easily?
(how does Killer Instinct 2 come out with a Mame set, but doesn't include the CHD required to play?)
I am trying to get this arcade cabinet completed for his upcoming birthday, and it seems like the Mame portion is the biggest hurdle.
Suggestions?
  • Last login:Today at 03:19:06 am
Re: N00B Dad Mame Setup Issue - Help Needed
« Reply #1 on: June 30, 2020, 01:10:36 am »
Suggestions?
1. Find the newest possible known version ROMset.
- If you can't identify which version of MAME the ROMset goes with, do not use it.  i.e. "MAME 0.216 ROMs" would be a good choice, but not "15,000+ MAME ROMs"
2. Download and use the version of MAME that matches your known version ROMset.
- If you have "MAME 0.216 ROMs", use MAME 0.216.
3. Same advice if you want to play games that need CHDs.
- Don't bother trying to find a single-file-download CHD set because many, if not most, CHD games are still not playable so the juice is not worth the squeeze.
- Try to find a source where you can download individual CHDs.
4. For game lists, see BadMouth's All Killer, No Filler lists.   ;D
« Reply #2 on: June 30, 2020, 08:49:42 am »
Thank you kindly.
I'll check out those lists.
Gilrock
« Reply #3 on: June 30, 2020, 09:32:45 am »
I keep it simple.  Just scroll through and find games you like then add them to Favorites.  I added about 60 games to Favorites and its the only list I stay in normally.  Then if someone asks for another game you can always go find it and try it.
