Author Topic: iPac 4 errors.  (Read 2597 times)
Bored28
  • Last login:July 06, 2020, 03:35:43 pm
iPac 4 errors.
« on: June 27, 2020, 06:04:45 pm »
My ipac4 is giving stuck key input on boot. The led flashes 5 times on boot and then stays out. Anyone got any info? Has the latest firmware and is in keyboard mode.
  • Last login:Today at 03:27:55 pm
Re: iPac 4 errors.
« Reply #1 on: June 27, 2020, 07:43:03 pm »
Check your connections -- you've probably got one of the input wires on an NC (normally closed) terminal instead of NO. (normally open)
The easiest way to troubleshoot this on a big control panel is to:
1. Power off.
2. Disconnect the daisy-chain ground(s) at the IPac.
3. Boot up the system.
- If you still have the error, something other than the daisy-chain is probably shorting an input to ground.
- It could still be an NC terminal connection problem if the daisy-chain is shorting to ground somewhere other than at the IPac.
-- Power down before doing a continuity check between the IPac ground terminal and the daisy-chain(s) -- the meter should read open/no continuity.
4. Open Notepad or a keyboard test program.
5. Carefully re-connect the daisy-chain ground(s) at the IPac.
6. Check the microswitch connections for the input corresponding to the pressed key(s).
Bored28
Re: iPac 4 errors.
« Reply #2 on: June 27, 2020, 11:27:19 pm »
Thank you for your response,
I unplugged the ground and still got the 5 flashes. I guess next is the keyboard test program. How would I do a continuity check?
Bored28
Re: iPac 4 errors.
« Reply #3 on: June 28, 2020, 12:06:15 am »
I also noticed I have one button that still works with the ground disconnected. This might be the problem.
Re: iPac 4 errors.
« Reply #4 on: June 28, 2020, 12:39:09 am »
That button's input is getting ground from somewhere.
- Is the IPac resting directly on a conductive surface (metal frame, ESD bag, etc.) instead of PCB legs or some other non-conductive surface?
- Is the daisy-chain connected to or touching frame ground? (metal power supply case, etc.)
- Did you remove all ground connections from the two"GND" terminals? (upper left of pic)
-- Sometimes people connect both ends of the daisy-chain to ground.
Make sure power is off, unless you want to fry your multimeter.   >:D
- The easy way to be certain is unplug the IPac's USB cable.
Here's a tutorial on how to use a multimeter.
Bored28
Re: iPac 4 errors.
« Reply #5 on: June 28, 2020, 12:48:57 pm »
It is kind of just floating right now because I didn't have a way to screw it down. Will it take the same screws as a motherboard? I may cover the back with electrical tape until I get that worked out. I did remove both ground wires on the board. I am going to get back at today. Kind of annoyed. Everything is done but the controller board.
Bored28
Re: iPac 4 errors.
« Reply #6 on: July 06, 2020, 03:35:43 pm »
Still trying to troubleshoot this. I pulled all the wiring and just plugged in the ipac4. It gives 5 flashes and then goes dim. That's all I got right now, is the ipac4 broken?
Re: iPac 4 errors.
« Reply #7 on: July 06, 2020, 03:58:01 pm »
That sounds like a reasonable diagnosis.
Not sure which error/condition causes the 5 flashes.   :dunno
E-mail Andy.
