Author Topic: Drop-in LED replacement for Flourescent Marquee Light?  (Read 1778 times)
nipsmg
  • Last login:October 21, 2025, 01:54:35 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« on: June 24, 2020, 10:24:43 am »
What is everyone using as a replacement for flourescent marquee lights.  On all 3 of my cabinets the bulbs died and I'm sick of replacing them.  I'd love something I can just drop in / use existing wiring to light.  Any good solutions that are pretty much plug (wire) and play?
  • Last login:Today at 07:11:58 am
Re: Drop-in LED replacement for Flourescent Marquee Light?
« Reply #1 on: June 24, 2020, 11:06:53 am »
There are led bulbs that plug straight into a fluorescent  fixture. I use them in my basement overhead light fixtures. I imagine they make them for smaller fixtures. There are also ones that have to be wired to bypass the ballast. Maybe it is an em ballast vs electronic ballast thing. I don't know.
I have over a dozen cabs. I hardly ever have a fluorescent bulb go dead.  :dunno
« Last Edit: June 24, 2020, 11:12:05 am by Mike A »
  • Last login:Today at 12:21:30 am
« Reply #2 on: June 24, 2020, 01:41:31 pm »
They are a good thing to replace though as the heat and UV rays will damage marquees over time.  At least in theory anyway.  I'm like you though.... never had one burn out and the one in my original mame cab is around 20 years old.
Titchgamer
« Reply #3 on: June 24, 2020, 03:26:49 pm »
As the others have said if its burning out regular you have a problem.
It could be it needs a new starter or ballast.
But on the flip side I to would swap it out for a LED fixture.
Under counter kitchen lights usually work well and I have used them a few times.
You will just have to disconnect the old one and wire in the new.
« Reply #4 on: June 24, 2020, 03:45:04 pm »
The flickering upon power up and the associated sounds are part of a classic arcade cab.
