Author Topic: Setting up Mame / Mala with rotating CRT (Mrotate4)  (Read 60734 times)
  • Moderator
  • Last login:September 20, 2025, 07:17:24 am
Re: Setting up Mame / Mala with rotating CRT
« Reply #80 on: August 22, 2020, 01:56:11 pm »
MRotate will create the ini file for you after you set it up the first time. It just stores all your settings (outputs, inputs, commands, etc.)
If it still slaps your hand over the mscomm32.ocx file, try placing the mscomm32 in windows\system32. If that dont work and your system is 64 bit,  try windows\SysWOW64. you may need to include mscomm32.dep file. Both are available in my mrotate5 package download, or you can probably find it on the web. (Shouldnt need this for 32 bit)
But if you could open the test panel with no hand slaps, you should be ok.
You can hook two leds to your output pins (with 500 ohm resistors) to test it, or wire into your system and give it a real test (get ready to pull the plug on your system just in case it dont do what you expect).
Also, dont forget what I said about the pins going to neg 12 volts to ground when turned off. If this will be a problem on your system you  will need diodes to block the negative signal.
I can give you a rough drawing showing how to hook up the diodes if you need it.
Ropi Jo
  • Last login:January 30, 2024, 04:26:37 pm
« Reply #81 on: August 22, 2020, 02:10:15 pm »
Thanks for getting back to me so soon. Please see in red....
MRotate will create the ini file for you after you set it up the first time. It just stores all your settings (outputs, inputs, commands, etc.) But I have no idea what to set the 'settings' to. Do I just leave them all as default?
But if you could open the test panel with no hand slaps, you should be ok. It seems that after double clicking the ocx file it stopped nagging about it.
I can give you a rough drawing showing how to hook up the diodes if you need it. I'm fine with the electronics part  thanks (that's where my strength is)
A few more Qs...
Do have to do something to make mrotate.exe start with mala?
Or will it run by itself?
Where should I actually put mrotate.exe?
  • Moderator
« Reply #82 on: August 22, 2020, 02:28:27 pm »
I had a long post typed out for step by step instructs, and I guess I timed out before I posted and lost everything. i hate when that happens.
Anyway, you can probably use defaults, as long as you tell mrotate which pins you are connected to. (Setup Main menu  Comm Port  inputs/outputs)
Also make sure you have the correct com port set. (Setup Main menu Comm port  Comport settings)
The default arguments are 0 for horizontal and 90 for vertical. you can use these.
To interface this with mala, in startcom, select the path where you have mrotate4 placed.
Then for arguments 0 for horizontal and 90 for vertical.
Mala tells startcom, startcom runs mrotate4.
You can also run Mrotate4 from the windows command prompt.
Open cmd in the windows search bar, open command prompt.
Change directory to the one where you placed mrotate4.
to run to horizontal, Type Mrotate4 0
to run to vertical, Type Mrotate4 90
to open setup to make any changes, Type Mrotate4
In startcom, you will need to type in the complete path to mrotate4. its a lot easier to just put Mrotate4 on the root, (C:\mrotate4)
I will try to do a complete tutorial with screen shots later.
Ropi Jo
« Reply #83 on: August 22, 2020, 02:51:29 pm »
I have everything in C:\Emulation. Guess I should put mrotate in there as well?
  • Moderator
« Reply #84 on: August 22, 2020, 09:48:52 pm »
You can. It really doesnt matter where you put it but startcom needs the complete path to it. Its just easier for me to remember if I keep it simple. C:\Emulation\mrotate4.exe is pretty simple.
  • Moderator
Re: Setting up Mame / Mala with rotating CRT (Mrotate4)
« Reply #85 on: August 22, 2020, 11:50:32 pm »
Ok, here are instructions for setting up mrotate4.
There is also pics of how to set up start com in mala to run mrotate4.
Sorry if I made any typing mistakes, its late.
I have laid them out in the order that you need to go by to set it up.
Main menu:
Comport connections:
Comport settings (mscomm32.ocx)
Outputs and Inputs:
Time limits:
Options:
Sounds:
Test panel:
About:
Mala plugin options:
Mala startcom:
Good luck, and holler if you need help, and let us know how it turns out.
Ropi Jo
« Reply #86 on: August 23, 2020, 05:39:55 am »
That is fantastic and so kind of you to take the time and trouble.
I'm off out with the family for a 90th birthday meal so will try to implement all this when we get back and update.
BTW... it's not my 90th!
  • Moderator
« Reply #87 on: August 23, 2020, 10:53:13 am »
Safe travels and tell them Happy Birthday from DaOld Man.
Ropi Jo
« Reply #88 on: September 05, 2020, 02:56:43 pm »
Today I installed the serial card and mrotate4. Followed your step-by-step to the letter...... and it worked exactly as you described. Used a couple of LEDs with 1K resistors and could see the outputs doing their thing.
As you also said, there is quite a bit of activity during windows boot so need to block the outputs for about 30 seconds, which is no problem. Also will add some blocking diodes for the -ve voltages you mentioned.
Salvaged a couple of optos, transistors and relays from some old boards and started with the interfaces.
Getting real close now!
Ropi Jo
« Reply #89 on: September 06, 2020, 03:03:52 pm »
Built the interfaces today. One of the 2 didn't work straight off and while investigating I blew up the opto, the back emf diode and the switching transistor. Decided I was doing it the hard way with pnp switching so redesigned and built both with npn. Much simpler and both worked 1st go. Using a 10K current limiter into the opto I only draw 0.45mA from the 5v test supply so very pleased with that. When I add the blocking diode I may need to drop the 10K a bit lower. Then just got to add the 30 second lockout timer and it'll be ready to hook up
  • Moderator
« Reply #90 on: September 06, 2020, 06:01:51 pm »
Thats great!
If you are using optoisolators you probably wont need the blocking diodes. The led in the opto is a diode anyway.
Im glad you are getting there.
Some pics would be real nice.
Ropi Jo
« Reply #91 on: September 06, 2020, 06:35:20 pm »
Never really played with optos before so wasn't sure how they would handle the reverse voltage. Already blown up one so don't want to screw up again. But you're right, the LED in the opto should just stay hard off. I'll go for it as-is.
You're also right about the pics... if there's no pics it didn't happen!!
One strange thing I found.... my optos are 6 pin, so the base of the o/p transistor is on a spare pin. When I handle the board I inject 50hz (UK standard) into that pin and the relay turns into a machine gun! I didn't have any 4 pin optos. As long as I didn't touch a certain area of the board with bare skin there was no spurious behaviour so I'll leave it alone.
« Last Edit: September 06, 2020, 06:39:22 pm by Ropi Jo »
Ropi Jo
« Reply #92 on: September 06, 2020, 07:00:41 pm »
Read this....
The base connection of the photo-transistor can be left open (unconnected) for maximum sensitivity to the LEDs infra-red light energy or connected to ground via a suitable external high value resistor to control the switching sensitivity making it more stable and resistant to false triggering by external electrical noise or voltage transients.
If I add a 10K to pull the base to ground I wonder how much more current will be required from the switching line?
Have to do a little testing. If I can keep the switching current to just 1 or 2mA with a base resistor added I think that would be good.
  • Moderator
« Reply #93 on: September 06, 2020, 08:18:00 pm »
Did you look up the spec sheet for that opto?
Its probably got a min current on input.
Im not sure what current the comm port is good for, but I would say 5-10 ma should be safe.
I know the old printer port was safely good for around 10 ma.
Ropi Jo
« Reply #94 on: September 08, 2020, 05:59:08 pm »
Connected up the interface in place of the rotate buttons after work today.
Just brilliant! I select a H game in Mala and the screen does it's thing. Same with V. I am really blown away with how this works.
I cant give enough thanks to DaOldMan for all his help with this.
He wrote the programs. Even rewrote mrotate (mrotate4) specifically for my build. Gave me step by step instructions. All in his own time for no reward. Genuinely one of the good guys and there's not many of them left  :applaud: :applaud: :applaud:
Got a bit of tidying up to do as it's hooked up with various wires hanging all over the place then I'll get some pics and probably a video or 2 showing some of the moving parts and Mala selecting games.
Got some more control panels to build next and also got to finish getting my roms sorted and loaded.
No rush though. It's onlt taken 6-7yrs to get this far! :cheers:
  • Moderator
« Reply #95 on: September 08, 2020, 07:20:16 pm »
Congrats!!
Thank you for the kind words, and I was very happy to help out.
Automatic rotation trumps manual (pushbutton), would you agree?
Cant wait to see the pics and the video of your creation.
Ropi Jo
« Reply #96 on: September 12, 2020, 03:54:43 pm »
Done a bit of tidying with the wiring and was about to get a video but there was one major bug that was giving me a real headache.
The auto rotate is the main thing on the cab, and it has to work well, which is does... sort of. The drive is through a bundle of plastic gears out of a foot massager and they chatter and rattle so loud they ruin the whole effect. So today I ripped them out and thought how else I can go about this.
In my junk box I've got a few 24V linear actuators salvaged from some hospital beds. I can't use them as-is but I stripped one down and the worm drive is virtually silent and so smooth. Did a bit of modding to the drive and the cab and looks like a good bet. Too fast with 24V but seems about right with a 19V laptop supply. Trouble now is that the motor runs on after hitting the end stop. Got to come up with a simple electronic brake. A momentary relay that shorts the motor when power is removed from the motor, or something like that. Have to do a bit of thinking tonight.
  • Moderator
« Reply #97 on: September 12, 2020, 04:40:54 pm »
Hmmm, so you are saying it is coasting? Can you move the stop switch to activate a little sooner?
Ropi Jo
« Reply #98 on: September 12, 2020, 06:20:11 pm »
There's so much weight in the 25" crt it takes about 3/4 inch to stop.  I should be able to come up with a simple electronic brake using bits from the scrap box.
« Last Edit: October 08, 2020, 09:50:10 am by Ropi Jo »
Ropi Jo
« Reply #99 on: September 24, 2020, 03:56:57 pm »
The Mk2 rotate mechanics are now finished and the improvement is better than I could have hoped.
Instead of a rattly clunky jerky and generally crap system it's now smooth and quiet and simply brilliant (in my very biased opinion ;))
Also added the auto brake so it stops where I want it.
A bit of tidying up (again) and it's definitely video time.
So, the next question.... how do I get a vid on here?
  • Moderator
« Reply #100 on: September 24, 2020, 07:22:40 pm »
Sounds good!
Its been a while since I uploaded a video to here, but if I remember correctly, you save the video to youtube or some other file sharing site, then post a link to the video here.
PL1 might be more help on this subject.
  • Last login:Today at 03:35:45 pm
« Reply #101 on: September 24, 2020, 08:43:14 pm »
Most vids are going to be too big to upload here so your best bet is to upload it to a video site like YouTube, Vimeo, Rumble, etc.
The forum software will auto-embed YouTube videos -- just put the URL without tags in your post.
If you post this:
Code: [Select]
https://www.youtube.com/watch?v=0_aIkkObZWM
It will embed like this:
If you don't have an account at one of the video sharing sites, you can upload to a filesharing site like Mega, Dropbox, Google Drive, etc.
- https://www.sendspace.com/ and https://www.zippyshare.com/ are filesharing sites that don't require an account, but files are only available for a limited time.
- The downside to this approach is that people will have to download the video to view it.
Ropi Jo
« Reply #102 on: October 03, 2020, 09:37:13 am »
VIDS ARE UP ON YOUTUBE
The vids are crap, but they sort of show the machine in operation. Just got 1 hori and 1 vert loaded for testing, and no CP fitted.
Vid 1... shows from the front https://www.youtube.com/watch?v=VIa63ozWEI0&feature=youtu.be
Vid 2... shows some of the workings https://www.youtube.com/watch?v=ZvK7TeRr6fQ&feature=youtu.be
The video quality is questionable, and the audio is far too sensitive. It's nowhere near as loud as the camera makes out. I can't even hear the buttons clicking but the camera makes them sound like gunfire. And the rotate is near silent but the camera makes it sound like a fog-horn.
« Last Edit: October 03, 2020, 09:42:06 am by Ropi Jo »
  • Moderator
« Reply #103 on: October 03, 2020, 10:46:09 am »
Looks good!! Can you show how you implemented the actuator motor to the rotation? I dont see that in the video.
Did you use a timer to delay rotation until PC booted up?
Can you share some wiring diagrams of your drive setup?
Ropi Jo
« Reply #104 on: October 03, 2020, 12:23:47 pm »
Here goes... (but still struggling with pics)
PIC 1.... This is the drive...
PIC 2.... The drive connects to the cog, which drives the toothed belt left over from my son's 3D printer build a few yrs ago...
PIC 3.... The Limit Switches
PIC 4.... The Serial Interface Board
PIC 5.... The Rotation Control Board
PIC 6 and 7.... The Auto Degaus Board
PIC 8.... The CRT And Surround (without the glass screen)
So, the basics...
At power ON, the timer relay on the rotate interface board (which is powered by the 12V from the ATX) will lockout the spurious outputs from the serial port for 30 seconds (this is adjustable).
When the PC boots and Mala is started it will be in the orientation of the last game played (thanks to Startcom). When V game is selected, Mrotate gives the output pulse on the Serial Port pin assigned. The interface board then powers a relay which activates the rotate system.
The rotate system, once activated, uses  2 relays to immediately block any further inputs, while at the same time activating 2 further relays. One will supply the drive voltage in the correct polarity and block out the other, or vise-versa, depending on direction of rotation. This state in permanent until the limit switch is hit. If a limit is not hit is the time set on the rotation timer relay the whole circuit is killed. This should hopefully never happen!!! When a limit is hit, a few things happen....
1.  The rotation supply is disconnected and the rotation circuit resets ready for the next input.
2.  The Motor Brake Relay is activated. This puts a resistor across the motor contacts for a couple of seconds to avoid over-run.
3.  The Auto Degaus fires the appropriate PTC for 1 second.
There are 3 PTC fitted. One for auto c/w, one for auto anti c/w, and one for manual. As the auto PTCs are only fired for 1 second, and they are used alternately, and they are fan cooled, even if the rotate is operated at the fastest possible frequency, the PTC has cooled sufficient to be ready for use. Hopefully the manual PTC, fired from a switch behing the coin door, will never be needed.
Some more notes...
The rotate motor is only running on 12V even though it is a 24V motor. With the full 24V it draws around 8A on startup and runs far to fast. This will cause the relay contacts to fail and also cause over-run. At 12V the rotation is nice and smooth and controlled.
My machining capabilities are quite limited so the drive cog is not perfectly centered on the drive shaft. The CRT mounting disc, around which the toothed belt is fitted, is also not as perfectly round as I would have like. This combination of imperfections caused the drive mech to go tight / slack / tight / slack during operation, causing a very jerky rotation. I added the rather elaborate (and probably over engineered) tensioning rollers to get around this and the rotation is now nice and smooth.
Unfortunately I am a messy worker, and my circuit drawings were no more than scribbles with loads of alterations and scribbles and I struggled to understand them myself once I'd finished with them. If anybody does need this info I'll try to recreate them in a neat fashion. But, to be honest, I only went with all the relays (and timer relays) as they were what I had in my scrap box. My son thinks I am positively pre-historic, and said if he was doing this build he would have controlled everything via an Arduino with PWM motor drives, H Bridges, and other far more modern techniques. I admit that computers and Arduinos are far out of my area of competence.
I hope this info and the pics and videos are of use to some people out there, and will do another update when I have built the rest of the machine (mainly the hot-swap CPs) and loaded on loads more games. I'll also be asking more questions regarding Mame / Mala, as obviously I'll be wanting to hide all the DOS boxes that keep showing and make Mala auto start at boot, which I know are all possible.
I must say another massive THANK YOU to DaOld Man, without who's help this machine would have never got off the ground :cheers: :cheers: :applaud:
« Last Edit: October 03, 2020, 02:24:12 pm by Ropi Jo »
  • Moderator
« Reply #105 on: October 03, 2020, 04:27:51 pm »
Wow! Your mechanical engineering is very impressive.
Thanks for the kind words, Im glad I could help.
So, do you prefer the automatic rotation over the manual pushbuttons?
Ropi Jo
« Reply #106 on: October 03, 2020, 07:38:37 pm »
Any rotate is better than no rotate, but auto-rotate just takes it to another level.
The few people who've seen it so far have definately been wow'd, with the possible exception of my dear old mum. When I showed her last week she started questioning if I was really her son! :dunno
