Author Topic: Groovyarcade usb zero delay  (Read 2270 times)
jcapone
  • Last login:June 19, 2020, 04:45:53 pm
« on: June 13, 2020, 01:35:14 pm »
hello, does anyone know how to configure these for controls? Search isn't working for me
buttersoft
  • Last login:Today at 02:42:44 am
  • Is running at 15kHz
Re: Groovyarcade usb zero delay
« Reply #1 on: June 14, 2020, 01:17:58 am »
Ignore bits in yellow, ignore turbo/auto fire unless you know you need it. You only need one connection to your joystick, either the sanwa one, or the one to the right of that, depending on the cables you want to use.
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #2 on: June 15, 2020, 08:52:11 am »
Does the device report as a keyboard or a HID ?
psakhis
« Reply #3 on: June 15, 2020, 12:08:42 pm »
As HID, it's different than ipac or jpac i think.
Sereosh
  • Last login:August 26, 2023, 11:27:13 am
« Reply #4 on: June 15, 2020, 12:12:45 pm »
MAME should have no problem detecting input from these encoders, I've used a couple. Go in the Inputs menu and assign the buttons as you wish.
