Author Topic: VMM and ArcadeOSD command line switches?  (Read 1761 times)
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
« on: June 06, 2020, 07:31:03 pm »
Well, as the title suggests, I'm trying to find all the command line switches for VMM and ArcadeOSD. Couldn't find them included with the files, nor on geedorah and not here. Search option doesn't work unfortunately, so I'm not sure if this was posted.
Thanks.
buttersoft
  • Last login:Today at 05:37:18 pm
  • Is running at 15kHz
Re: VMM and ArcadeOSD command line switches?
« Reply #1 on: June 07, 2020, 03:07:23 am »
Does either one use commandline switches, though? If you type help into VMM it will give you a list, i believe.
