Author Topic: Megatouch ml-1 freezing issue  (Read 4993 times)
Cmdr470
  • Last login:August 20, 2020, 10:52:07 am
« on: May 29, 2020, 01:41:42 pm »
Recently got a megatouch ml-1 for a great deal. I have played megatouch machines forever but have no experience working on them. When the machine plays lower resolution games it works great. When I play the higher resolution games or two player games, the machine starts to have to work harder and freezes about every 20 seconds. On some occasions it freezes and then has to reboot. Have no idea what the problem is. Any ideas?  Thanks ahead of time.
mahkeymike
  • Last login:Yesterday at 03:58:50 pm
Re: Megatouch ml-1 freezing issue
« Reply #1 on: May 29, 2020, 04:07:25 pm »
It could either be the garbage 5400 rpm sata drive going, or your GFX daughter board is over heating. I would check to make sure the fans are spinning.
Cmdr470
« Reply #2 on: June 13, 2020, 12:17:47 pm »
Thanks for responding. As far as I can tell, there are three fans. One up top, one towards the bottom, and one on the motherboard. The fan on the mother board isn’t spinning. Not sure if it is supposed to spin 24/7.
mahkeymike
« Reply #3 on: June 14, 2020, 06:09:50 am »
Its absolutely should be spinning 24/7. Do not run the machine until you replace that fan, or you are going to have a very big paperweight.
Cmdr470
« Reply #4 on: June 14, 2020, 12:54:54 pm »
Again...thank you for responding. I apologize, I am a noob when it comes to this stuff. Are you saying just the fan needs replaced and not the entire motherboard?
mahkeymike
« Reply #5 on: June 14, 2020, 06:07:49 pm »
Im saying the reason you are having freezing issues is because your Motherboard is overheating due to that fan not working anymore. If you continue to run the ML-1 without that fan cooling the motherboard down, its going to die.
Cmdr470
« Reply #6 on: July 27, 2020, 08:20:59 pm »
The fan will work upon first turning the power on. But after about 20 seconds, it stops and does not come back on. Tried to order a new fan but the plug harness was too big. Thanks for your help. Much appreciated.
mahkeymike
« Reply #7 on: July 28, 2020, 10:11:09 pm »
No problem. PM me when it dies and i'll buy it.
