Author Topic: WG K7500 issues  (Read 2215 times)
mclovin
  • Last login:December 15, 2025, 11:59:25 pm
  • GT newbie
WG K7500 issues
« on: May 23, 2020, 09:56:53 pm »
Hello all, I have a wg k7500 and all is good except the vertical position. I can adjust the pot on the remote board but i can not adjust the veto so position just can stretch it larger.
Anyone have any suggestions? I have about an 2” gap at the top of the monitor that I can’t fill.
Thanks in advance
mclovin
  • GT newbie
Re: WG K7500 issues
« Reply #1 on: June 03, 2020, 07:57:45 pm »
Bump...-anyone?
grantspain
Re: WG K7500 issues
« Reply #2 on: June 04, 2020, 08:43:48 am »
does your chassis have the vertical hold pot on the main chassis, it should be near the v def ic
mclovin
  • GT newbie
Re: WG K7500 issues
« Reply #3 on: June 06, 2020, 10:45:25 am »
No mine does not have that pot.  :dunno
grantspain
Re: WG K7500 issues
« Reply #4 on: June 07, 2020, 04:57:23 am »
i will look at the schems a bit later, so your fault is no adjustment on vertical shift whatsoever but the pot and connection from remote to chassis are all good?
mclovin
  • GT newbie
Re: WG K7500 issues
« Reply #5 on: June 07, 2020, 11:57:16 am »
The connection is good. Not sure about the remote pot. There is only very slight movement when adjusting the remote pot. How would I test that pot?
grantspain
Re: WG K7500 issues
« Reply #6 on: June 07, 2020, 12:10:09 pm »
you can test the pot with a meter
check Q602 and R619
mclovin
  • GT newbie
Re: WG K7500 issues
« Reply #7 on: June 09, 2020, 11:28:41 am »
The pot is fine. I’ll see if I can figure out how to check the others. Thanks
