Author Topic: ION-EVO not booting  (Read 4163 times)
Randy0777
  • Last login:May 20, 2023, 01:46:31 pm
ION-EVO not booting
« on: May 20, 2020, 12:48:58 am »
Hi, need some help please...
A little background on the game. I picked it up at a flea market, and you could see that someone tried to pry it open...with no luck.
I already had two at home, so I figured for parts. Jump ahead 7 years (I've been busy :) ) Since being stuck at home, I'm running out of things to do, so time to work on the game again.
Looked up everything, and looks like they broke the board loose from the mounting screws. Made sure nothing was touching, powered it up, D-sub cable error. Checked the battery, 2.8V so replaced it. Jump the pins on the P/S and board comes to life (Lights only), still D-sub error.
Hooked the monitor up to a PC and it was good. Pulled the MB out, no obvious caps blown . Its the ASUS K8N-VM board, my other two are the purple boards.
So, I was thinking about replacing the board and CPU with a upgraded one, if thats possible ?
I figured it was either the MB or CPU.
Any suggestions would help. Thank you.
PS they never did get in it, still 3$ in BV  :banghead:
mahkeymike
  • Last login:November 08, 2025, 12:13:04 pm
Re: ION-EVO not booting
« Reply #1 on: May 20, 2020, 08:54:27 am »
Bad onboard video chip. Needs new mobo.
Randy0777
« Reply #2 on: May 21, 2020, 02:10:26 am »
Thank you for the reply.
From reading , it looks like the D945GCLF2D MB is a direct fit ??? Is this still the best option for a replacement ? I see a few on Ebay, with the CPU.
Is there anything special I should look for?
 Looking at the specs for that MB, it says use DDR2 400/533, 2GB max.g Does it matter which size I get, as long as its 512 or higher?
justtaint
  • Last login:September 08, 2021, 06:11:05 pm
« Reply #3 on: May 21, 2020, 06:35:32 pm »
As I read in another thread, From Lilshawn "either the asus or if you have a post 2009 software install, the D945GCLF or D945GCLF2 (first year implemented) it runs cooler and produces less heat overall.
either way, you are looking at doing some mods to get it in there."
http://forum.arcadecontrols.com/index.php/topic,130306.40.html
I went with the Asus A7N8X-VM in my Ion EVO because someone on Craigslist was selling mobo, cpu, ram combos for dirt cheap.
I had to trim 3 of the fins on the Northbridge heat sink to get the I/O board to fit, took all of 30 seconds with a dremel and a cutting disc.
« Last Edit: May 21, 2020, 06:38:02 pm by justtaint »
Randy0777
« Reply #4 on: May 25, 2020, 10:43:20 pm »
Jumping the P/S has helped quite a bit previously, however, this time I had to jump the MB. All is good  :applaud: Thanks for the replies.
  • Last login:October 27, 2025, 06:16:21 pm
« Reply #5 on: May 26, 2020, 01:05:17 am »
looks great man!  :cheers:
Ken Layton
  • Guru
  • Technician
« Reply #6 on: May 26, 2020, 10:46:36 am »
Merit Field Bulletin 54 addresses power on problems:
http://www.meritgames.com/Support_Center/Bulletins/PDF/FLDBLL54.pdf
I had to get that harness from Betson to get an Ion Evo that came in with a "no power up" problem to power on. The harness completely replaces one that came with the machine. It has redundent grounds so the machine will power on consistently every time.
See this thread too:
http://forum.arcadecontrols.com/index.php/topic,149849.0.html
« Last Edit: May 26, 2020, 10:48:38 am by Ken Layton »
