Author Topic: Mamehooker Mame 0.220, Windows 10 64bit and Outrunners  (Read 4335 times)
LukeS
  • Last login:November 05, 2021, 09:49:32 am
« on: May 17, 2020, 03:48:04 pm »
Hello:
I'm trying to set up Mamehooker on Windows 10 and Mame v0.220.
I have read the tutorial over and over again and I can't get it to detect Mame's startup.
I am trying to configure it with the game Outrunners, as in the tutorial by (trying) generating a file like the one below:
[General]
MameStart=
MameStop=
StateChange=
OnRotate=
OnPause=
[Output]
ma_steering_wheel_lamp=ffe 1 stop|ffe 1 offroad3
[KeyStates]
RefreshTime=
What name should the file have?
Is it necessary to configure something in Mame ( apart from starting it in window mode)?
By the way, I have Thrustmaster TMX Force Feedback.
Thank you very much for your support.
« Last Edit: May 17, 2020, 04:19:18 pm by LukeS »
baritonomarchetto
  • Last login:December 16, 2025, 01:54:13 am
Re: Mamehooker Mame 0.220, Windows 10 64bit and Outrunners
« Reply #1 on: May 18, 2020, 02:10:51 am »
You must activate outputs in mame by setting the variable "outputs" to "windows" (it is set to "auto" by default).
Then I would start by testing your peripheral with mamehooker "test" submenu. Thsre's no need for a running game for this test, so you avoid a possible source of issues.
To answer to your first question: when mamehooker "hooks" the running game a file called "romname.ini" will be autogenerated in mamehooker's "ini" folder.
Follow word-by-word Howard instructions, starting from the first tutorial to the last ;)
« Last Edit: May 18, 2020, 02:14:14 am by baritonomarchetto »
LukeS
« Reply #2 on: May 18, 2020, 02:50:32 am »
Thank you very much!!!
I had even read the official documentation but it doesn't say anything about the windows option.
In the documentation only the following options appear, as you can read here:
https://docs.mamedev.org/commandline/commandline-all.html
OSD Output Options
-output
    Chooses how MAME will handle processing of output notifiers.
    You can choose from: auto, none, console or network
    Note that network port is fixed at 8000.
It was driving me crazy!!!
« Last Edit: May 18, 2020, 02:52:51 am by LukeS »
lllll44
  • Last login:August 09, 2025, 10:29:49 am
« Reply #3 on: June 12, 2020, 04:13:27 pm »
what is mamehooker? for lcd lights output?
LukeS
« Reply #4 on: July 28, 2020, 05:29:10 pm »
Not only for LCD lights. Force Feedback (or rumble) also support.
