Author Topic: Using an ipac controller to drive a popashot bball game motor  (Read 3819 times)
HitTheShowers99
  • Last login:July 08, 2020, 08:53:05 pm
  • Just a small town girl living in a lonely world
Howdy all, looking for direction on how to use an ipac to control a motor that drives a bball net. The game itself has no original parts, it's a shell that I put an ipac in running "free hoops" software found in this forum. I'm thinking I could just splice a switch into the harness and add a plug but there wouldnt be any on/off timer function. Hope this makes sense. Any help much appreciated.
  • Last login:Today at 06:39:22 pm
Re: Using an ipac controller to drive a popashot bball game motor
« Reply #1 on: May 14, 2020, 02:27:02 pm »
The IPac is an encoder that translates button presses into keystrokes/gamepad button presses/mouse clicks, so it can't directly control the motor, but you're on the right track with tapping into the existing wiring.   ;D
Based on your posts on this subject, you may want to try an approach like this:
1. At the IPac Start switch input, add a second wire leading to an input on an Arduino.
- When you press the Start switch, ground will be applied to both the IPac and Arduino inputs which will trigger both of them.
- Arduino Pro Micros are inexpensive and should work well for this application.
Start switch _______________ IPac input
                                             |_ Arduino input
2. You'll need to write an Arduino "sketch" (program code) that does the following:
- Initialize and start the program loop.
- Read the input.
- When the input is triggered, start a countdown timer.
- When the timer reaches a certain value, command the motor driver or relay(s) to move the motor as desired.
-- The exact commands to use depend on the type of motor and the desired behavior.
-- You may need to use limit switches to keep the motor from going too far in either direction.
-- Try to time things so the motor returns to the starting position just before the timer runs out.
- When the timer runs out, kill power to the motor driver/relay(s), re-initialize, and start the program loop again.
3. You'll need some type of motor driver board or relay(s).
- Not sure if that is an AC, DC, or stepper motor.
- The motor will draw more current than USB can provide, so you'll need a power supply for it.
-- If the motor runs on 5VDC or 12VDC, you can get that from the computer's Molex connectors.
First step is to identify what type of motor it is (AC, DC, or stepper) and what voltage it runs on.
That will lead you to how to control it.
- 1 relay for AC.
- 2 relays for DC. (may need limit switches)
- Motor driver board for stepper. (may need limit switches)
That info combined with the desired timing and actions leads to the Arduino program code.
Automated Projects is a good sub-forum to check for info on motors.
Raspberry Pi & Dev Board is a good sub-forum to check for info on Arduino code.
HitTheShowers99
« Reply #2 on: May 15, 2020, 05:46:42 pm »
Thank you, very much appreciated. Ordered the Arduino and will try it out. I think the motor was 115/12v 6 rpm.
