Author Topic: Installing UltraStik 360 Oval Top  (Read 1400 times)
yanivw
  • Last login:May 14, 2020, 10:19:40 am
« on: May 05, 2020, 03:04:58 pm »
Hi all,
I'm now planning a control panel for a new build I start soon.
my question is regarding bottom installation of the UltraStik 360 on a 3/4" plywood.
What is the recommended diameter for the center hole of the joystick so the handle can move freely?
I didn't see any comment regarding this on the product page (https://www.ultimarc.com/arcade-controls/joysticks/ultrastik-360/)
I'll appreciate any help from members who has experience with this product.
Thanks in advance,
YW
famawizard
  • Last login:August 18, 2025, 06:01:45 pm
Re: Installing UltraStik 360 Oval Top
« Reply #1 on: May 06, 2020, 07:46:23 am »
Hi,
if, in the future, you will install the front/top restrictor, the diameter of the hole in the cabinet must be 33mm.
DJO_Maverick
  • Last login:August 18, 2025, 05:32:31 pm
  • Chrono Crosser
« Reply #2 on: May 07, 2020, 04:35:33 pm »
I have unrestricted 360s on my 3/4" panel; Andy advised 1" holes were adequate.  I made 1 1/8" holes because that was the size Forstner bit I already had for the buttons.  It has given more than enough clearance, and plenty small enough to be covered up by all dust washers I've tried.
yanivw
« Reply #3 on: May 08, 2020, 02:05:05 pm »
Many thanks!  :cheers:
uptown47
  • Last login:December 01, 2025, 09:34:57 am
  • Just takin' life one game of Frogger at a time...
« Reply #4 on: May 17, 2020, 10:20:10 am »
I was testing different hole sizes yesterday for ServoStiks and found the smallest I could get away with was 18mm so I suppose anything up from that is fine. The black plastic hole-cover-thing is massive so, if you're using that, then you'd get away with a much larger hole. :-)
