Author Topic: Groovymame not rotating games  (Read 3537 times)
abispac
  • Last login:November 28, 2025, 07:58:36 pm
« on: April 23, 2020, 02:08:17 am »
As the tittle says ,ive setup rotation settings in the mame ini, but launching games and they dont rotate, if i manually use command line, -ror they do start rotated, its like the ini its ignoring the rotation option in the ini file. now some other options are being read by gm,as skip game disclaimer works just fine, thanks for any help.
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini;ini/presets
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
swpath                    software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
rewind                    0
rewind_capacity           100
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
lowlatency                1
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       1
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
fallback_artwork
override_artwork
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
comm_framesync            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
language                  English
nvram_save                1
# SCRIPTING OPTIONS
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   generic_15
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_port             23946
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
waitvsync                 0
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_lut
bgfx_avi_name             auto
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
attach_window
# DIRECT3D POST-PROCESSING OPTIONS
hlslpath                  hlsl
hlsl_enable               0
hlsl_oversampling         0
hlsl_write                auto
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
distortion                0.0
cubic_distortion          0.0
distort_corner            0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_variation        1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
chroma_mode               3
chroma_conversion_gain    0.299,0.587,0.114
chroma_a                  0.64,0.33
chroma_b                  0.30,0.60
chroma_c                  0.15,0.06
chroma_y_gain             0.2126,0.7152,0.0722
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_beam_smooth        0.0
vector_length_scale       0.5
vector_length_ratio       0.5
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.0
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.06
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.01
lut_texture
lut_enable                0
ui_lut_texture
ui_lut_enable             0
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
# FRONTEND COMMAND OPTIONS
dtd                       1
buttersoft
  • Last login:Today at 07:16:55 pm
  • Is running at 15kHz
Re: Groovymame not rotating games
« Reply #1 on: April 23, 2020, 02:33:17 am »
monitor                   generic_15
Should be changed to rotate_r or rotate_l, is that what you want? This change would launch vertical games rotated one way or the other, but leave horizontal ones alone. You may also need to set aspect:
screen                    auto
aspect                    auto
to 3:4. Only do this if the image goes too far off the sides (sides being relative to normal horizontal orientation of monitor).
« Last Edit: April 23, 2020, 07:04:15 am by buttersoft »
abispac
« Reply #2 on: April 23, 2020, 09:20:11 am »
monitor                   generic_15
screen                    auto
aspect                    auto
:cheers: thanks.
buttersoft
« Reply #3 on: April 23, 2020, 07:12:49 pm »
I should have said, you may need to make the aspect change in a vertical.ini file, or else it might mess with the aspect of horizontal games as well.
abispac
« Reply #4 on: April 24, 2020, 02:17:42 pm »
I dont plan to use horizontal games on this setup, thanks sir. by the way, how can i for a certain video mode or resolution to a particular game? i know i can create an ini for each game but what does it need to have inside? thanks in advance.
buttersoft
« Reply #5 on: April 25, 2020, 06:20:18 am »
any sub ini file is just mame.ini with whatever options you want to be different to mame.ini. If the lines are the same as the mame.ini you can leave them out altogether and only include what you want changed.
if you want to force a resolution, use the line called that, i think eg:
screen                    auto
aspect                    auto
resolution                640x480
That chunk above is just showing you where to find the resolution line. You could make a raiden.ini file containing that single line, if you wanted to.
« Last Edit: April 25, 2020, 06:22:29 am by buttersoft »
