Author Topic: placled64 not detected by pc  (Read 1087 times)
toppe
  • Last login:April 19, 2020, 01:53:47 pm
« on: April 19, 2020, 12:28:27 pm »
hello everyone, and the first connection in this forum, a question and thank you who will be able to answer me.
I have a placled 64, suddenly it is not detected by the PC's USB soket (I have also tried on other useless USB ports) it also makes a strange "interference" noise, I state that I use it connected together with other cards on a professional USB HUB, any advice ??
thank you very much
Titchgamer
Re: placled64 not detected by pc
« Reply #1 on: April 19, 2020, 01:26:27 pm »
Bit confused so just to clarify, Are you saying that your PC has several knackered USB ports and you are running this via a hub from one good one?
Or are you saying that the PAC64 does not work in any USB slot?
If its the latter do other devices work?
toppe
« Reply #2 on: April 19, 2020, 01:53:31 pm »
yes the other devices work, but right now I did a test, I powered the card with the 5 volts of the PC power supply, and now everything works, mah, why do you think?
Titchgamer
« Reply #3 on: April 19, 2020, 03:19:01 pm »
You had the power connected to the USB?
If so that is/was your problem!
The board needs a clean supply voltage :)
