Author Topic: Ipac software  (Read 2043 times)
Jukeboxmike
  • Last login:September 15, 2021, 06:46:04 am
Ipac software
« on: April 07, 2020, 09:47:10 am »
Hi all.
I have been using DWjukebox as the software for my jukebox for quite a few years now.  Up until recently I have used a hacked keyboard controller for my buttons. I found this a bit unreliable and have made 3 of these over the years and all have eventually failed.
I decided to go down the proper route and use an Ipac2 instead.
Unfortunately after all sorts of problems, I have not been able to use the Ipac software to program the buttons in my XP (32 bit) based jukebox.  The lates error that I recieved when trying to open the program I get a message - winipac.exe is not a valid Win32 application.
I have tried re-installing several times but no change.
I can get the program to open and work without problem (from the same downloaded file) on my Win10 PC.
My question is this. - Can I set up my key codes on the win10 pc and then use the Ipac on my winxp jukebox.  I am assuming that the keycodes are stored on the Ipac.
« Last Edit: April 07, 2020, 09:49:33 am by Jukeboxmike »
  • Last login:Today at 12:04:50 am
Re: Ipac software
« Reply #1 on: April 07, 2020, 10:02:26 am »
Yes.
Jukeboxmike
Re: Ipac software
« Reply #2 on: April 07, 2020, 10:14:31 am »
Thanks PL1
That is the way I will do it then.
