Author Topic: Joystick Mounting Screws  (Read 2954 times)
sleong
  • Last login:December 26, 2021, 04:11:56 pm
  • Novice builder of Arcade Machines
« on: April 03, 2020, 02:16:11 pm »
Hello everyone,
In the process of putting together a bartop unit and want to know whats the best way to mount joysticks to a 1/2" particle board control panel?
I'm guessing screws would not be very efficient as when playing sometimes the force of players would push too hard and just knock the joystick off.
I would guess carriage bolts would be the best bet? or how do most of you mount your joysticks that gives it a nice finish on the surface?
Steve
  • Last login:Yesterday at 12:49:15 pm
Re: Joystick Mounting Screws
« Reply #1 on: April 03, 2020, 02:24:23 pm »
Carriage bolts. All the way through. Just like God commanded.
  • Last login:Yesterday at 06:20:48 pm
« Reply #2 on: April 03, 2020, 02:33:35 pm »
Embrace the carriage bolt. It’s how the our arcade  forefathers did it.
sleong
« Reply #3 on: April 03, 2020, 02:39:32 pm »
Where would be the best place to get those? Lowes, Home Depot, Rona (Canada) etc.??
« Reply #4 on: April 03, 2020, 02:42:16 pm »
Home Depot has them.
sleong
« Reply #5 on: April 03, 2020, 02:43:59 pm »
Thanks for the quick responses. . . . . . Since I am still not in home isolation and still got work I guess will need to wait for the weekend to pick these up!
« Reply #6 on: April 03, 2020, 06:55:12 pm »
Actually, if you have an Ace Hardware Store nearby, those are the best places to find them
meyer980
  • Last login:January 26, 2026, 08:20:18 pm
  • Building fun things for fun
    • Sergio Stuff
« Reply #7 on: April 03, 2020, 07:17:33 pm »
I'm surprised (but super curious) about the carriage bolt in wood thing. How do you get squares for the carriage bolts to stay in? And do you under-mount the joystick so that's it's still flush on top?
« Reply #8 on: April 03, 2020, 07:34:34 pm »
When you tighten the carriage bolt down the round hole becomes square because steel beats wood.
MartyKong
  • Last login:January 09, 2026, 12:25:53 pm
« Reply #9 on: April 03, 2020, 07:38:23 pm »
Carriage bolts are definitely the most secure way to mount this. Using 3/4" plywood and a router I was able to under mount my joysticks because it would mess with my artwork. Other guys screw bottom pieces of wood to undermount joysticks to not mess with artwork. Lots of ways to solve this problem. If not for artwork, I would have gone with traditional carriage bolts. A quick joystick mounting search should give you plenty of ideas 8)
  • Last login:Today at 05:26:21 am
« Reply #10 on: April 03, 2020, 09:17:33 pm »
Carriage bolts are probably the best choice for your 1/2" panel.
The FAQ has a good list of mounting options.
http://wiki.arcadecontrols.com/index.php/FAQ#Joysticks
The difficult part of using threaded inserts like the ones from GGG on a 1/2" panel is that the insert needs a hole that is at least 0.345" deep to fullly seat it -- there's not much wiggle room.
« Last Edit: April 03, 2020, 09:21:49 pm by PL1 »
sleong
« Reply #11 on: April 04, 2020, 01:25:20 am »
Scott that was an informative site.
I was just considering undermount since it is only 1/2" and not much room to work with.
Using T-Nuts or similar would work but need more time to create that T recess. Not really what I want to do...
Giving it thought with the carriage bolt I wonder if the control panel will be strong enough before it gives way when tighting the bolt into the wood...
I though of using those IKEA screws then capping it with those plastic caps. To avoid any scratches to the hand when playing of slips.
« Reply #12 on: April 04, 2020, 04:18:12 am »
Carriage bolts are used for undermount.
- Felsir and I forgot to include that method and diagram in the wiki.   :embarassed:
The joystick body is positioned like the "Under mount (tee-nuts)" diagram in the wiki, but there's no tee-nut recess and the bolts should be head up/threads down like the fasteners in the "Top mount" diagram.
Yes, the panel will be strong enough that you can tighten the nut and crush the square part of the bolt down into the round hole.
You won't need caps.  Carriage bolt heads are rounded.
The threaded end and nut are below the panel so there's nothing to scratch your hand.
Worst case scenario:  You find ones that are the right size, but have markings on the head.
- Thread several nuts on the bolt.
- Tighten your power drill chuck on the nuts.
- Use sandpaper to remove the markings as the drill turns. (Poor man's lathe.)
Hoopz
  • Intellivision Rocks!
« Reply #13 on: April 04, 2020, 10:52:02 am »
Somebody here was selling black carriage bolts and if I recall correctly, no lettering on the head. Peale maybe. Or Randy? It's been awhile.
The forum search is still borked and using Google to search this site came up with a bunch of threads that you may want to browse.  YMMV.
Hoopz
« Reply #15 on: April 04, 2020, 12:56:06 pm »
Good job Scott. You're a good kid.  :applaud:
