Author Topic: Groovyarcade Tab menu Blury  (Read 2324 times)
aj8302
  • Last login:April 02, 2020, 08:48:34 pm
« on: April 02, 2020, 06:36:01 pm »
So I’m having a problem where the tab menu is all blurry and can’t read it. Even though My game and text in game look fine. Is this a common an issue? Does any one know how to fix it that can hopefully help me?
Substring
  • Last login:January 22, 2026, 05:27:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: Groovyarcade Tab menu Blury
« Reply #1 on: April 02, 2020, 06:56:26 pm »
You need to change the mame font. Depending on the groovyarcade version you're using it's more or less easy
aj8302
« Reply #2 on: April 02, 2020, 07:23:06 pm »
In not sure what version in running of mame. I guess what ever came with the groovyarcade live CD 2019 running on Lenix. Is there a good tutorial that I can use to change it?
tyson171
  • Last login:December 07, 2022, 09:34:22 pm
« Reply #3 on: April 02, 2020, 10:39:04 pm »
Here is how i fixed this on my machine.  I just worked through the same issue -
I'm using winscp, as i'm not a strong linux user.
Download and connect to your machine with WinSCP
I used root, you need to enable this via console first or your might get rights issues -
Root login over ssh can be enabled by the doing following steps,
Login as a root user. use any text editor, here i am using vim editor. (if your using mlocate in linux, you can just search for sshd_config)
vim /etc/ssh/sshd_config
uncomment the line below line
PermitRootLogin yes
I then rebooted my machine ( you can just restart ssh also)
Now in WinSCP you need to enable hidden files -
Open up Options - Preferences - Panels - Check "Show Hidden Files"
I was missing the fonts file, so i downloaded Groovymame for windows, extracted it to a folder, and copied over the following file from the root to the directory below - uismall.bdf
Now we need to copy the font file over to the Mame Fonts folder -
/home/roms/MAME/fonts
Finally we need to edit the mame.ini
Edit the mame.ini located here -
/home/arcade/.mame
Search for the following line below and add the font type we copied over -
uifont    uismall.bdf
Save the mame.ini and thats it!
If you have any issues let me know, this assumes some basic linux/windows knowledge, but you can google all of those parts.
There is probably a MUCH MUCH easier way to do this, but I'm like I mentioned I'm not very strong in Linux, so I cheated with winscp and got it done however I could figure it out.
« Last Edit: April 02, 2020, 10:42:37 pm by tyson171 »
Substring
« Reply #4 on: April 03, 2020, 03:14:33 am »
Hey that's a good answer :)
The groovyarcade fork I'm working on already has the uismall font. But even better : the april release should be much more eye candy regarding the mame menu ;)
