Author Topic: Groovyarcade with multiple gpu?  (Read 2522 times)
Ericthegreat
  • Last login:July 29, 2025, 02:13:12 am
« on: April 01, 2020, 06:40:53 am »
My cabinet isn't far from my PC so I plan to put an 8570 in my pc with my 980ti, when I run groovyarcade if I disconnect my monitor from the 980ti would that be enough for groovyarcade to choose the Radeon gpu instead, it'll really suck to remove my gpu all the time.
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: Groovyarcade with multiple gpu?
« Reply #1 on: April 01, 2020, 06:49:28 am »
Which groovyarcade version are you running ? Using Nvidia gpus will very soon be possible. In fact it is possible if you do a few edits by yourself. You need a kernel 5.5 patched with the corresponding 15kHz patches from Doozer
Ericthegreat
« Reply #2 on: April 01, 2020, 07:36:32 am »
Just got my cab, waiting for stuff (like the vga cable and graphics card), could you share me a link, would make my life easier if I could just use my 980ti, it only has DisplayPort,dvi-d, and hdmi, I guess id need an active dvi-d to vga adapter for analog, not sure if that works? All of this is going to a jpac.
(id also still like to know if anyone has run this with 2 gpu)
« Last Edit: April 01, 2020, 07:39:44 am by Ericthegreat »
Substring
« Reply #3 on: April 01, 2020, 08:36:15 am »
You need an analogue output. DVI-D is digital only. DP wouldn't be better. You might jave better chances with HDMI, but i haven't tried.
There is no documentation (yet) as it's something Calamity and Doozer have helped me to get working. And to tell you the truth, I got it working successfully just a week ago. I can give you a link to a work in progress version of groovyarcade that you may test, it has nvidia support. It can be used as a livecd, no need to install if you just want to try
Ericthegreat
« Reply #4 on: April 01, 2020, 08:46:23 am »
Hmm HDMI to vga says minor video quality loss, I wonder how much, sure I'll take a copy thank you so much :)
I'll definitely need it if I can't get the 2 gpu thing working.
Anyone know if HDMI to vga will cause overscan issues?
« Last Edit: April 01, 2020, 08:51:49 am by Ericthegreat »
Substring
Ericthegreat
« Reply #6 on: April 01, 2020, 10:04:53 am »
Thank you very much, does it work well?
Substring
« Reply #7 on: April 01, 2020, 10:33:12 am »
I've only tested a GT210 with DVI-I, worked rather fine !
