Author Topic: Install retroarch in groovyarcade?  (Read 2259 times)
Ericthegreat
  • Last login:July 29, 2025, 02:13:12 am
« on: April 01, 2020, 02:51:01 am »
Is it possible? Also I have a 980 ti plugged in as well but I want to use my Radeon 8570 for groovyarcade, can I leave my 980ti plugged in as long as no monitor is connected to the 980ti?
arfink
  • Last login:August 25, 2024, 01:02:16 am
  • Narf!
Re: Install retroarch in groovyarcade?
« Reply #1 on: April 01, 2020, 03:46:30 am »
It's possible, but you'd have to compile and configure it yourself for Arch. I would suggest using the Mednafen suite it comes with for console emulation. That should get you covered for NGPC, NES, SNES, GBC, GBA, Genesis, LYNX, PCE, PS1, and Saturn, plus a few more I'm not remembering, and it's already on there and set up to work with 15khz tubes like you want.
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #2 on: April 01, 2020, 06:47:11 am »
He said groovyarcade, not GroovyMAME. So i guess he means Linux and not windows. So no emu4crt.
I guess this is possible, depends on the version of groovyarcade you're using, and how your linux is configured to not use your 980ti for display
