Author Topic: Raspberry pi 3b ,can it output 15khz without hardware?  (Read 14156 times)
abispac
  • Last login:March 11, 2026, 07:33:42 pm
« on: March 29, 2020, 06:44:02 pm »
Hey, iv used google with no luck, so far all solutions use some kind of hardware, so i was wondering if someone here knows a way to output the resolution on a crt arcade monitor. Thanks for any help.
Substring
  • Last login:Today at 03:43:55 am
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: Raspberry pi 3b ,can it output 15khz without hardware?
« Reply #1 on: April 01, 2020, 02:11:52 pm »
I can through DPI/GPIO or with a HDMI2VGA. In both cases, you'll have to use super resolutions as the raspberry pixel clock is very limited.
abispac
« Reply #2 on: April 02, 2020, 11:41:07 am »
isnt hdmi2vga a piece of hardware? because im looking to achieve this without hardware, thanks
keilmillerjr
  • Web Developer.
« Reply #3 on: April 02, 2020, 10:17:24 pm »
It can, through composite or gpio.
mamemaniac
  • Last login:Today at 05:12:30 am
« Reply #4 on: April 03, 2020, 08:09:07 am »
Do you have a webpage or info how to hook it up and configure it with the GPIO?
abispac
« Reply #5 on: April 03, 2020, 02:39:35 pm »
 :pics :pics :pics
Substring
« Reply #6 on: April 04, 2020, 07:14:41 pm »
You need Gert VGA 666 at least. Devices such as Retrotink are not anymore available for sale.
abispac
« Reply #7 on: April 04, 2020, 11:17:52 pm »
what part of without hardware,do you guys dont get?
« Reply #8 on: April 05, 2020, 01:57:39 am »
The answer to your question is no.
abispac
« Reply #9 on: April 05, 2020, 01:28:48 pm »
:cheers: its that simple, thank you sir.
Substring
« Reply #10 on: April 16, 2020, 06:01:06 pm »
Probably because a PI just has HDMI, GPIO and USB. And among those 3, nothing natively outputs 15kHz without some (hardware) magic. So the question was probably bad.
keilmillerjr
  • Web Developer.
« Reply #11 on: June 23, 2020, 02:05:40 am »
All raspberry pi units to date have composite interlaced and later firmware progressive.
Osirus23
« Reply #12 on: June 28, 2020, 10:52:21 am »
Yep, 240p from the built-in composite jack. So yes, Rpi3 can output 15khz without hardware. I think the OP is bailed on us though.
snoopyk
  • Last login:January 02, 2021, 03:13:13 am
« Reply #13 on: January 02, 2021, 03:12:37 am »
HDMI@VGA and VGA@Scart  working!!!.  Scart input R,G,B, and Sync..  connect to Arcade monitor, it might work, you then need to edit the cfg file. I didn't try it on the arcade monitor but it worked 15khz on the Scart tv, I think it will work on the arcade crt monitor as well. in arcade automat I have 15khz already from RPI3B + with Vga666. For me, it is easy to buy Vga666 and download the finished image, you need PinHP, RGB-PI, Regamebox, etc ...
Sorry my english ..
mahuti
« Reply #14 on: January 03, 2021, 11:51:15 am »
Fyi, though my answer includes hardware, the simplest solution ive found is to use a Jpac.
I've used GertVGA....shrug... its fine... but was missing a piece when I ordered it, so it took a long time to get it going. I've tried a few converters (but they were garbage... didn't save settings on restart, stopped working, etc). At some point I had custom firmware that let me output 15hz via composite (before that was officially possible) directly to an arcade monitor, but for some reason I didn't like that solution either. One day I plugged in my jpac and it worked fine. One and done.
Jpac is a known quantity, easily available and has other value as well. Unless price is the absolute determining factor, I'd consider it the obvious option.
