Author Topic: Scrambled/rolling display  (Read 1312 times)
Mistouch
  • Last login:March 04, 2020, 09:52:01 pm
« on: March 04, 2020, 01:12:56 pm »
Originally posted in the groovymame thread, thought I should cross post incase it falls under the monitor thread.
Monitor: Nanao MS8 29FSG
Radeon HD 7570 SFF
Hooked up from the DVI-I to VGA to jpac/jamma
Followed the instruction guide found on geedorah forum to get the driver set with 15khz however at the end where I hit the "enable edid emulation" the image on the Nanao monitor displays a mess which I have no idea why.
New to the arcade hobby so I might be missing something. Image looks to be squished and all scrambled.
Settings
On the monitor screen. Looks to be a scrambled version of my desktop screen
gonzalma
  • Last login:April 03, 2020, 09:07:02 pm
Re: Scrambled/rolling display
« Reply #1 on: March 05, 2020, 01:16:06 pm »
I might be behind the curve but I didnt think that you could get a 15 khz signal via a DVI port even with an adapter.  That scrambled signal looks like what I have seen when the signal is not correct.  The card you are using has to have an analog out VGA.  But my information might be outdated since I built my cabinet.
The Beatings will continue until Moral Improves...
fuchi_jeg
  • Last login:Today at 11:40:05 am
« Reply #2 on: March 05, 2020, 05:26:30 pm »
That's a sync issue. It is possible to sync with a dvi-i to vga passive adapter.
