Author Topic: Hantarex Polo 25/28 Squealing  (Read 2394 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: March 01, 2020, 05:37:37 am »
Hi
What can cause this?
My monitor is Squealing..
I thought that it just where a bad solder joint on the neck board at the focus wire but it looked fine to me.
« Last Edit: March 01, 2020, 05:46:55 am by perjmolsen »
grantspain
Re: Hantarex Polo 25/28 Squealing
« Reply #1 on: March 01, 2020, 07:37:00 pm »
replaced caps?
perjmolsen
    • My gameroom
« Reply #2 on: March 02, 2020, 01:04:09 am »
Hi
No not yet, I have just looked for cold joints.
 I am thinking to start with the polyester caps near the flyback, would that be an idea?
grantspain
« Reply #3 on: March 03, 2020, 05:07:43 am »
they are worth checking
you should check the earth pins on the flyback and the earth through screw near the power input
perjmolsen
    • My gameroom
« Reply #4 on: March 04, 2020, 05:37:52 pm »
Hi
An update
I have now
- Tested all the volts, they are good.
- re-flowed all the pins at the flyback.. same issue
- Put in new polyester caps .. same issue
- changed flyback to a new one.. same issue
I am thinking it might be a sync issue?
So i have tried to change C149 and C150... same issue
Also tested T110 and T112, they tests OK
Next thing is to replace IC104 with a new TDA2593
grantspain
« Reply #5 on: March 05, 2020, 02:33:45 am »
in the video it loses focus for a second, it could be related to crt socket
do you get same issue with no signal applied and raster obtained
perjmolsen
    • My gameroom
« Reply #6 on: March 05, 2020, 11:38:24 am »
Hi Grant  :cheers:
When I have no signal applied (also test video is OFF at the adjustment board)
I get this on screen when i turn up the screen volts at the flyback
If I turn down screen volts at flyback I still have that strange sound, but no picture of course :)
Strange what causes that flickering and squealing sound....
I have looked at the pins and socet at the neckcard, they all look fine.
I am still thinking if it can be  IC104??
I have some new ones.. so do you think it is worth trying to put in a socket and a new IC?
« Last Edit: March 05, 2020, 12:07:01 pm by perjmolsen »
perjmolsen
    • My gameroom
« Reply #7 on: March 05, 2020, 01:54:33 pm »
Hmm...
Not IC104... I have changed it still the same
princess prin prin
  • Last login:Yesterday at 06:15:21 am
  • intrinsically safe
« Reply #8 on: March 05, 2020, 02:45:31 pm »
It's one of the new flybacks that are available now. Why did you replace the old one? If you have an original one, try that.
perjmolsen
    • My gameroom
« Reply #9 on: March 05, 2020, 03:13:29 pm »
Yes it is a new style one.
I just replaved it to see if it where the cause.
But it did not change anything.
I will put in the old one again.
perjmolsen
    • My gameroom
« Reply #10 on: March 05, 2020, 04:18:55 pm »
Put the original flyback back.. still the same issue...  :dunno
grantspain
« Reply #11 on: March 05, 2020, 04:49:48 pm »
looked at the crt socket, looks ok must be ok then
