Author Topic: Not sure that my refresh rate is changing with respect to the game loaded  (Read 1825 times)
Vectorfire
  • Last login:October 30, 2025, 11:32:59 am
Is there a tool that can display the current refresh rate and resolution on screen when a game is loaded into GM?
I don't believe that my refresh rate and resolution is changing with respect to the games that I am loading.
High resolution, 31khz titles look extremely blocky and fuzzy as through they are being displayed at a lower res. Naturally my low res games look fine, which is why I'm  thinking something isn't changing.
Shouldn't my CRT's sync circuit be making a clicking noise when I switch from a low res to high res game? Because that's not happening.
Is there a tool available that would display the current refresh rate and resolution that I can see onscreen when I am in-game?
MY ini is attached and my specs are in my sig, let me know if you need anything else to help diagnose.
Thank you!
Groovy_Mame Rig:
Windows 7 Home Premium
Intel i7-3770K @ 4.50ghz
16gb DDR3
Creative SB0730 X-Fi Xtreme Gamer
Sapphire Dua-X R 280 Radeon: DVI-I-->VGA adapter
Ultimarc Video Amplifier
27" Makvision Tri-Mode Monitor
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
Re: Not sure that my refresh rate is changing with respect to the game loaded
« Reply #1 on: February 16, 2020, 01:44:28 pm »
Run the game you want to test with logging enabled.
mame64.exe RomName -v > log.txt
make sure to run it from a folder that doesn't need permissions if the log comes out empty.
Besides that you should be able to see the resolution picked while running the game in Machine Information.
« Last Edit: February 16, 2020, 01:47:55 pm by Foxhole »
