Author Topic: Planar WS231 LCD Monitor Power Pinout Needed  (Read 1535 times)
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« on: February 08, 2020, 07:37:03 pm »
Hello.
I have a Planar WS231 LCD monitor. It had no power supply. I just found a power supply at a Goodwill that has close specs, and the correct 4-pin plug. But I don't want to just plug the thing in and hope it works.
Does anyone have the specs on the 4-pin plug? I know it's 12V, 6A. But I don't know which of the pins are power and which are ground. I checked the manual and the pinouts are not listed. I also tried to find this info online.
Thanks.
Re: Planar WS231 LCD Monitor Power Pinout Needed
« Reply #1 on: February 08, 2020, 09:07:27 pm »
manual says
12V /6A, 72W
Universal Input AC Adapter (External)
https://www.planar.com/media/222795/mn-planar-ws231.pdf
i'd suspect the pin is negative and the outside positive. you can verify with a voltmeter by seeing if the pin is connected to exposed metal (like the vga connector) it should be no resistance.
not sure what 4 pin dealy you are looking at...as the manual appears to show a standard barrel jack.
« Last Edit: February 08, 2020, 09:09:32 pm by lilshawn »
Mario
« Reply #2 on: February 09, 2020, 02:19:42 pm »
Great tip about checking the grounding. Thanks.
I just found this Alibaba item showing a pinout, so I can hopefully verify if this matches the Planar inputs. This plug matches the jack on the Planar monitor.
Mario
