Author Topic: 1080i on 25khz crt monitor?  (Read 2442 times)
xbrunox
  • Last login:August 30, 2025, 05:03:06 pm
« on: February 03, 2020, 04:33:31 pm »
Hi all
Sorry if this question is stupid...
Is possible install a 1080i resolution on a 25khz crt arcade monitor?
« Last Edit: February 03, 2020, 05:14:36 pm by xbrunox »
Substring
  • Last login:Today at 03:28:40 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: 1080i on 25khz crt monitor?
« Reply #1 on: February 03, 2020, 05:44:14 pm »
Nope. Switchres said :
Code: [Select]
$ ./switchres 1920 1080 60 --monitor arcade_25
#  1920x768@60.07 24.9600Khz
ModeLine          "1920x768x60.07" 59.304855 1920 1960 2192 2376 768 771 781 831 -HSync -VSync interlace
buttersoft
  • Last login:Yesterday at 05:16:21 pm
  • Is running at 15kHz
« Reply #2 on: February 03, 2020, 11:37:25 pm »
1080 (lines) x 25 (fps = 50i)  = 27kHz.
So no, even if you could squeeze the vertical blanking interval down to nothing, and you were willing to live with 50i, you'd still be over any 24kHz range limit.
