Author Topic: LED Blinky Jukebox lighting issue  (Read 1298 times)
Propdept
  • Last login:June 16, 2022, 05:26:16 pm
« on: February 01, 2020, 05:58:13 pm »
I have led Blinky and had it pulsing the buttons to light according to the music played by Juke box
Everything was working fine until today
Please be aware I am running window 10 professional I am using the sound card that is built in to the motherboard it is a Realtek sound application
The Juke box will not light the buttons. But all other led Blinky functions seem to be working
These are the errors I am getting...
*No audio device found
*No audio inputs found
*Invalid audio device value this may occur if you have changed your audio hardware. Please deselect the audio DEVICE
In the drop down menu for audio device no selection is showing
(I didn’t change any audio hardware.  I did Install a new joystick)
*Error initializing  audio functions
*Bass Record Int Failed
Error Bass Error device 23
Be aware in Audio Animation Options
The Audio Device and Input when you click on the drop down to the left nothing is listed
It’s like all of a sudden this function stoped working :banghead:
Help :hissy:
« Last Edit: February 01, 2020, 09:42:18 pm by Propdept »
Propdept
Re: LED Blinky Jukebox lighting issue
« Reply #1 on: February 02, 2020, 05:19:11 pm »
 :woot :wootUPDATE:   I solved it. Turns out in December I plugged the computer onto the internet and it downloaded a new driver and that screwed it up. Since I have not played the jukebox since December.  I was working on other things with the Cabinet.
 :cheers:  To all of you and especially Arzoo, THANK YOU!
 I’m getting drunk right now  :dizzy:
I’m not kidding. I deserve it!!!!! :woot :woot :woot
« Last Edit: February 02, 2020, 05:46:42 pm by Propdept »
SpuRge79
  • Last login:March 18, 2025, 09:40:53 am
« Reply #2 on: April 26, 2020, 03:04:19 pm »
I have the same problem. How did you fix it?
