Author Topic: Zero Delay ports keep switching after reboot  (Read 2005 times)
mrl72
  • Last login:May 10, 2020, 04:26:57 pm
« on: January 30, 2020, 05:11:35 pm »
I have 3 zero delay USB boards that show up as Generic USB controllers in Windows 10. Installing them was a real pain as I would plug one in as Joy 1 then add the 2nd which would show up as Joy 2 then when I plug in the 3rd it would switch places with Joy 2. I have 3 banks of USB ports on my PC, 4 in the front, a row of 2 on the rear, below it another 4 then another 4 below that for USB 3.0. I spent an hour plugging and unplugging each one in random ports until I had the order correct. Then at some point, after a reboot more than likely, they switched order again! Urgh.
Has anyone seen this before? Is there a workaround before I throw these in the trash?
esoteric_rt
  • Last login:July 16, 2024, 08:04:33 pm
Re: Zero Delay ports keep switching after reboot
« Reply #1 on: January 30, 2020, 05:20:11 pm »
I would be interested in advice on this also,
Normally my boards stay configured, even after a cold shutdown of the PC. However if you remove the USB cables from the PC, you need to reconfigure then
« Reply #2 on: January 31, 2020, 01:28:24 pm »
It's been years since I looked into this, but I remember using a utility before that ordered USB devices in order to keep them in place.
Not sure if this is it, but should hopefully give you a starting point.
https://answers.microsoft.com/en-us/windows/forum/all/change-the-order-of-game-controllers/d12b351d-1457-46c0-850a-118c8809e1ca
In theory, it should be no different than solving for ordering multiple USB controllers on a PC.
mrl72
« Reply #3 on: January 31, 2020, 02:20:57 pm »
Awesome, thanks! I'll give this a go and see if it does the trick!
