Author Topic: Voltage question re PWB-2022  (Read 1695 times)
esmith
  • Last login:January 28, 2020, 10:00:05 pm
  • I do build my own arcade controls!
« on: January 22, 2020, 02:07:14 pm »
Hello,  Newbie here,  cannot find info on a PWB-2022 chassis.
Cocktail cabinet,  old Sega Gremlin.  Had a 100 volt 13 inch monitor,  pulling 100 volts from the isolation transformer.  it eventually died.
Picked up a new 13 inch CRT.  Came with a pwb-2022.  Does this run at 100V or does it run at 115v?
Can you harm the monitor by running it under voltage at 100v if it is meant to run at 115V?
Any information would be greatly appreciated.
Thank you,
