March 11, 2026, 08:49:00 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Main Forum
Blackened soldering iron
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Blackened soldering iron (Read 950 times)
Gideon
Trade Count:
0
Full Member
Offline
Last login:January 15, 2026, 04:48:25 am
on:
February 16, 2004, 05:57:09 pm »
Is the barrel of this thing supposed to turn black? It's my first time using one, and I was wondering if I did something wrong...
The reason why I ask is because when I see pics of soldering irons in tutorials online, they aren't black like mine.
Logged
Jakobud
Trade Count:
+1
Full Member
Offline
Last login:
Yesterday
at 10:09:01 am
Re:Blackened soldering iron
Reply #1 on:
February 16, 2004, 07:04:55 pm »
Its just like soot and smoke and stuff. Just clean it off. Keeping it clean will help the soldering better because then you know the metal is right up against the solder.
Logged
MAME Skip Startup Frames plugin
MAME Free Play plugin
MAME Config Generator plugin
JustMichael
Trade Count:
+1
Full Member
Offline
Last login:September 27, 2015, 01:19:40 am
Mmmmm!! Cheesecake!!
Reply #2 on:
February 16, 2004, 07:06:33 pm »
Some will turn different colors do to the heat but the barrel really doesn't matter. As long as the tip is shiny then you are ok. The tip is the part that is supposed to be melting the solder.
Logged
DrewKaree
- AHOTW - Pompous revolving door windbag *YOINKER*
Wiki Master
Trade Count:
+1
Full Member
Offline
Last login:May 15, 2021, 05:31:18 pm
HAH! Nice one!
Reply #3 on:
February 16, 2004, 07:35:52 pm »
Having solder stick to your iron is not a good thing. Clean your soldering iron off. You should only touch the solder and the iron together when beginning, to get a bit on the tip to start.
The idea behind soldering is, this:
use the tip to heat the things you wish to solder until they are hot enough that, when touching your solder to the pieces to be joined, it melts and flows across the two, joining them together.
You should try to NOT touch the wire to melt your solder to join pieces. Eventually you will need to clean your iron of all the built up gunk on it.
For a better "how to" see here:
http://www.aaroncake.net/electronics/solder.htm
or here:
http://www.epemag.wimborne.co.uk/solderfaq.htm#howto
Hope this helps.
Logged
Minwah
Trade Count:
+3
Full Member
Offline
Last login:January 18, 2019, 05:03:20 am
Reply #4 on:
February 16, 2004, 07:52:04 pm »
I had an electric iron which turned pretty black along the barrel part - not thru touching anything, just thru heat. As the others said as long as the tip is clean you'll be OK.
The tip will blacken up over time tho, you can use a special wet sponge to clean the tip, or if you're like me and forget lightly file the crap off when it gets so bad it stops working
Logged
MAMEWAH - Multiple Emulator Front-End
Gideon
Trade Count:
0
Full Member
Offline
Reply #5 on:
February 16, 2004, 10:59:28 pm »
Thanks, guys. I appreciate your help.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
