Author Topic: How to secure an overlay on a Pacman/Ms Pacman / Pixel Bash cabaret?  (Read 1207 times)
pakupakuman
  • Last login:May 17, 2025, 05:32:34 pm
Hello -
I've seen several cabinet plans, as well as several build pages, but have not found a detailed description on hot to secure an overlay (glass or plexiglass) over a monitor.
Back in the day I had a couple of pinballs, and the glass was secured by three rails and a locking bar at the lower end (towards player) of the play field.  I would assume that a cabinet like the ones I've mentioned in the header have at least a top and bottom rail?  I'm interested in how the lower rail works.
Thanks, and Happy New Year!
Marcos
  • Last login:Today at 01:40:05 pm
Re: How to secure an overlay on a Pacman/Ms Pacman / Pixel Bash cabaret?
« Reply #1 on: January 02, 2020, 11:36:12 am »
no rails. usually just simple wood blocking.
3/4" x 3/4" wood blocking is placed at either sides of the cabinet in the monitor opening and a block placed at the bottom that has a notch cut into it to accommodate the thickness of the glass. then the control panel holds this down.
usually at the top, the glass tucks under a part of the cabinet that makes up the back wall
sorry, I didn't have time to build it to scale or MSpaint it.
it should give you a rough idea of what's going on anyways.
