Author Topic: Disabling C-Sync  (Read 1634 times)
MiteWiseacre
  • Last login:May 24, 2025, 03:52:24 pm
Disabling C-Sync
« on: December 30, 2019, 05:19:15 pm »
So I was messing around trying to get my little TV working with RBG and using my groovymame arcade machine to test it. I went into VMM and enabled CSync, it doesn’t work with my crt or with my vga monitor. I can’t see the screen to get back in and deselect csync.    :embarassed:
Help.
MiteWiseacre
Re: Disabling C-Sync
« Reply #1 on: January 05, 2020, 01:39:44 pm »
So I just had to connect another monitor to the digital out, go into crt_emudriver and uninstalling the driver.. then go to VMM and switch to a resolution my lcd screen likes.. restart with a vga lcd.. go through the crt emudriver setup and redo the usermodes and hotswap back to my crt.
Basically reinstalled emudriver and vmmaker.
How I messed it up so bad I’m not sure, a little scared to play with the c-sync setting in the future..
