Author Topic: Skee-Ball Model S Restoration Complete  (Read 8395 times)
MotoGP
  • Last login:December 28, 2024, 08:16:54 pm
« on: December 29, 2019, 10:49:47 am »
      Model S  June 1990
      This is a Model-S 13' alley I purchased that needed some serious TLC.
      I decided to strip it down and completely restore it. When I took it all apart, the inside looked like a cat was living in it.  The end of the alley had a lot of water dame so in lieu of trying to splice it together, I decided to shorted it 2' which fit in my space better.
      Since I finished it in October, it has been played over 1000 times.  It has been a big hit!  Everyone that comes over wants to play Skee-Ball.
      Condition when I got it
      • needed repainting
      • cork was shot, had been painted many times
      • score board did not work
      • wiring was a mess
      • water damage
      Upgrades:
      • new cork
      • LED score board from www.kahr.us
      • add 100 rings
      • added ticket dispenser
      Next I plan to add some LED lights down the alley.
« Last Edit: December 29, 2019, 10:53:59 am by MotoGP »
Re: Skee-Ball Model S Restoration Complete
« Reply #1 on: December 29, 2019, 11:24:43 am »
Damn that is so cool.  Looks great and you have the perfect space for it.
nipsmg
  • Last login:February 15, 2026, 06:33:19 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2 on: December 30, 2019, 10:30:59 am »
How are you scoring the 100 rings?  I didn't see the switches.  Are they on the backside of the scoring board?
MotoGP
« Reply #3 on: January 01, 2020, 07:34:15 am »
The switches are under the ramps a made.  the switch arm/wire goes through a hole and is bent 90 degrees so the ball rolls over it.  The ball only has a narrow path between the back board and the play field.  It works perfectly.
One issue I had with scoring was sometimes either the 50 or 100 would not count all of the switches.  I figured out it was a timing issue.  I used a 1/2" x 5" felt strip and stuck it across the ball track between the 30&40 holes.  This was just enough to slow the ball down a little.  Now this machine score perfect every time.
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« Reply #4 on: January 07, 2020, 04:04:14 pm »
Nice restoration.  Mind me asking what you paid for it originally?
MotoGP
« Reply #5 on: May 23, 2020, 09:54:55 am »
Sorry I'm just seeing this.  I paid $450 for it.  It came with 2 CPU units.  I had both of them tested / repair by Bay-Tek, not cheap but worth it.
santicity
  • Last login:June 27, 2021, 02:48:08 am
« Reply #6 on: June 25, 2021, 04:59:55 pm »
Super late to the party, but how did you add the ticket dispenser?
Also, how did you update your netting? Looking to replace mines as well :)
« Last Edit: June 27, 2021, 02:46:06 am by santicity »
MotoGP
« Reply #7 on: August 28, 2021, 06:11:55 pm »
sorry for the late response, I'm not getting notified for some reason.
The wiring for the ticket dispenser was already there, I just had to add a brace for mounting.  I bought the cover for the tickets on eBay.  I have an extra one I would sell.
the netting I just soaked it to clean it then painted it with fabric paint from Lowe's
